Ford 6000 cd not working
Username: Erniecd
have a ford 6000 cd player with cracked screen.
backlight comes on and accepts and ejects cd's but cannt get anything to play, radio or cd.
suggestions? could it need the code re input? if so how do you do that?
Also, is it possible to make some makeshift tools to remove the head unit?
Username: Regrooster
Post Number: 1617
Quote the Serial Number beginning with M++++++
found on a label on the casing.
Radio removal demo here using the correct extractors
http://www.fitaudio.com/videos/din_keys_guide/video_din_size.html
Alternatives are 2 pieces of bent , wire coathanger or 4 x small drills(use the blunt ends) or 4 x small Allen Keys or 4 x small screwdrivers or 4 x nails or even 4 x darts.
An assistant is useful to pull the radio out whilst you are releasing the 4 securing clips
Username: Erniecd
thanks RR
Serial: M242743
Post Number: 1624
Try code 5733
Username: Stoffe
Hey thanx for the tips on removing the CD. It really helped.
My Serial is M033530
Thanx in advance
/Chris
Post Number: 2006
Kristoffer Ekholm
Username: Stoffe
Registered: Oct-09 Posted on Friday, October 09, 2009 - 07:05 am:
Your code is 4881
Thanx in advance
