Silver Member Username: Solobaric4lifePost Number: 948 Registered: Jan-07 | I know i aint been on here in a while, but i need opinions on new below setups, i know im stuck on kicker, so ill at least be getting cvx models lol, im also a fan of higher tuned boxes cause my current setup is l7 12's on zx1500 4cu @ 47hz lol, it will make my eye balls pop out my head, literally i cant drive all the way up NEW : Amp AQ2200, heard it was true amp 4 cvx 10's 5.8cu @ 40hz OR 2 cvx 15's 7cu @ 40hz Both is after displacements i know some may suggest lower tuning, but im used to solob's @ 47hz, so for me cvx's should be wayy better @ 40hz in my 99 s10 blazer, just out of those exact 2 seups, 4 cvx 10's or 2 cvx 15's??? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12057 Registered: Jun-04 | The 15's have more cone area. |
Silver Member Username: Solobaric4lifePost Number: 950 Registered: Jan-07 | thaks bro, thats what i was leanin on, so in future, i can get 2 more and have 4 cvx 15's i know im stuck on them, but you know anything bout them, likkke they get close as loud as l7's? and sound lil better? |
Silver Member Username: Solobaric4lifePost Number: 952 Registered: Jan-07 | any1 have any experimence with the cvx's? or just heard them? |
Gold Member Username: Drant19DUB-C, TX Post Number: 1990 Registered: Aug-07 | i wouldd hate to see a box build with those subs in a box tuned to 40 hz...your gonna lose a lot of low end. my .02 |
Silver Member Username: Solobaric4lifePost Number: 954 Registered: Jan-07 | i know i will, but as i said im used to l7's @ 47hz, so the cvx's should be good for me @ 40hz, cause i like higher tuned bass, its louder to me. had my l7's in a box @ 34hz, and they sounded muuuch better than 47hz, but NO WHERE AS LOUD as the one @ 47hz i like eye poping bass but thanks for input |
Gold Member Username: Drant19DUB-C, TX Post Number: 1993 Registered: Aug-07 | L7's at 47hz... wow you must not like sound quality! |
Bronze Member Username: Mittens08Post Number: 23 Registered: Jun-09 | ive had a single 15 dual 4ohm cvx runnin in 1ohm with the box tuned to 36hz im pretty sure and it hit realll hard and killed the lows...the sq on the cvx is alot better then the l7s ive had a pair of 12 L7s and the one 15 hit cleaner and harder |
Gold Member Username: Drant19DUB-C, TX Post Number: 1995 Registered: Aug-07 | ^^ you must of had the L7s in a sh!tty box then... i find it hard to believe that 2 12" L7s didnt get as loud as a single 15" CVX...but ehhh whatevs man |
Silver Member Username: Solobaric4lifePost Number: 955 Registered: Jan-07 | well, will 37hz be any better yall think, cause i still want higher spl bass, here 2 box plans,for 2 cvx 15's 37hz vs 40hz ??? both around 7 cubes after sub and port displacements, but i really dont wanna go lower than 37hz also will the aq 2200 slam the15's close to there limit?? ive had no experimence with aq amps |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1154 Registered: Jan-08 | just build two boxes |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12063 Registered: Jun-04 | Yes the audioque 2200 will slam the cvx 15's just fine. |
Bronze Member Username: Mittens08Post Number: 24 Registered: Jun-09 | it was loud and the box they were in was a custom made box made for the L7s tuned to the right freq....they were prob louder db wise but sq with spl the cvx was alottt better...L7s and L5s are pooopy |
Silver Member Username: Solobaric4lifePost Number: 956 Registered: Jan-07 | "just build two boxes" thatsactuallya great idea, ill make one @ 40hz, and try one about @ 35hz, and just see then, i do know that the lower tuned will sound better, but ill check em both out, to suit my needs lol |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3776 Registered: May-07 | The L7 and cvx are pretty much the same sub, different shape for the most part. |
New member Username: MadquakePost Number: 1 Registered: Sep-09 | Anybody used a cvx in a sealed Box ??? |
New member Username: MadquakePost Number: 2 Registered: Sep-09 | Sorry a CVX 15 inch sub in a sealed box ??? if soo how much airspace please ?? |
Silver Member Username: Armykyle1Ms Us Post Number: 797 Registered: Dec-08 | I think the AQ will over power those subs but who knows. are you dead set on those subs? I would shoot for 36hz |
Gold Member Username: Drant19DUB-C, TX Post Number: 2058 Registered: Aug-07 | you should nab mike loudons stuff... RD alpha and sundown saz1500 https://www.ecoustics.com/electronics/forum/car-audio/591898.html |
Silver Member Username: Billybobjoesmithjr_th_3edSouth, TX US Post Number: 102 Registered: Sep-09 | that one is easier you have more cone space with four 10's...4x10 =40 and 2x15=30 so the 10's will be louder than the 2 15's |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 4146 Registered: Mar-07 | That isn't how you calculate cone area...just stfu and gtfo. Ex. 15'' / 2 = 7.5'' 7.5^2 x Pi = 176.71 sq in 2 15" = 353.43 sq in 4 10" = 314.16 sq in (without surrounds taken into consideration) |
Silver Member Username: Billybobjoesmithjr_th_3edSouth, TX US Post Number: 107 Registered: Sep-09 | looks like you need to go back to school if you don't know simple math |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 4148 Registered: Mar-07 | ...Obviously you need to go back to school. |
Silver Member Username: Billybobjoesmithjr_th_3edSouth, TX US Post Number: 109 Registered: Sep-09 | i made it through 10th grade and got my GED i know enough |
Gold Member Username: Hittin1TEAM REVOLUTION, La. Lake Charles... Post Number: 3939 Registered: May-07 | Steve.. this is obviously one of our regulars. Nobody is as stupid as this dude is pretending to be.... |
Diamond Member Username: WingmanaliveWww.stainles... .ecrater.com Post Number: 21173 Registered: Jun-06 | Logan was very fond of ghost writing. He did it allll the time. |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1133 Registered: Feb-07 | He is still a pain in the @ss and needs to GTFO |
Silver Member Username: Billybobjoesmithjr_th_3edSouth, TX US Post Number: 159 Registered: Sep-09 | i don't care what you say 4x10 =40 and 2x15=30 |
Gold Member Username: Big_edge_headMilwaukee, WI Post Number: 4149 Registered: Mar-07 | You're a fu<kin' idiot. I hope someone shoots you. |
Silver Member Username: Billybobjoesmithjr_th_3edSouth, TX US Post Number: 271 Registered: Sep-09 | you mad ? |
Gold Member Username: TurnmatWww.j-designs.org Post Number: 1191 Registered: Feb-07 | I will do it if someone gives me a gun...Kyle? lol |
Silver Member Username: DlavanteD&L Audio Tech. , Daniel Corvallis, O... Post Number: 242 Registered: Feb-07 | He cant be an actual person |
Silver Member Username: Billybobjoesmithjr_th_3edSouthside, TX US Post Number: 409 Registered: Sep-09 | you go with the 4 10's |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2744 Registered: May-04 | Willam is a douche bag! |
