So I have a custom $10,000 on atomic. He already has 3 H.O. alts and mids and highs. What would you do for subs and amps with this budget. Its going in an extended cab chevy truck in a wall. Right now he has 5 RE SE 15s on a JBL 2400watt amp. I just need to make sure I absolutely crush this. He said he wanted 4 RE MXs and 2 warhorses but I talked him into atomic because my competitor sells RE exclusively and I sell Atomic. what do yo think. I was thinking either 2 APXX 18s on a 7000.1 or 4 ELE 18s. I dont know what I should do yet.
i posted this for fun, i just wanted to know what you would do. i have already made the sale and decided on what i wanted to go with. it was an opinion thing.
post ended. I wasnt really asking for business advice, maybe i should hae stated it betteri n the first post. I was wanted to hear all the crazy ideas.
honesty not piss away 10k on some spl truck... no offesne, i mean for 2k you can build an amazingly loud S.Q./SPL CAR/TRUCKi mean for some Ads OR RAINBOW COMPONETS WITH A NICE CENTER CHANNEL AND THEN SOME GOOD 12'S OR 15 YOU WOULD A AMAZING S.Q. SYSTEM THAT WOULD BE PLENTY LOUD IT WOULD WITHOUT BEING ALL INSANE..... UNLESS YOUR CUSTY IS TRYING FOR SPL COMP.
M. Phil, please learn how to turn your caps off when you bump the key mid sentence. The "Caps Lock" key is located on the left side below "Tab" and above "Shift".
Seriously, $10,000 is nothing for subs and amps, but I'd feel like I was getting ripped off if I paid that much for 2 18s and 7k when the charging system was already there. I say 2 7ks and 4 15s/18s.
first of all, i never said i charged him 10 grand i just said that was his budget which means i dont need to go over it. the charging system is still weak because the batteries are only like hc800s or so and there are only 3 of them. also we are going to put an amp on mids and highs plus labor costs. so no it wont be 10 grand but i will accomplish not going over budget easily.
I could easily spoend more money on a SQ systemthen a straight SLP setup. There are Comp sets that are $3000+ each set. not including the amps and custom instalation. I would rather sp[end the money on SPL. Most people are not able to hear the difference from a $150 comp set and a $3000 comp set. Critical listening is not my thing. Just about every car audio fan can tell the difference between 2 sony xplodes and 2- RE XXX's.in good installs
X2 on mark. You can make your own comps too. Find tweets you like, a nice woofer. Subs I like to think of something with a light cone yet stiff. tuning between 27-31
If I had to spend near 10gs on a vehicle... DD component set on a C4 ~$500 Two DD 2510s with blue dust caps. ~$600 Two RD1750.1s - ~$700 Kinetik 1800 and 2400 - ~$600 Alot of 1/0 - $200 Air ride system - $4000 Paint job - $2,000 Rims - $900 Turbo charger - $2000 Custom Interior - ~$1000
i think you should save a little more and buy my tahoe already setup.
has brand new 24s and brand new tires, 8,500.00 candi blue paint with 12 color flakes.
8 batts, 2 alts, couple grand of sound deadner, 12,000 watts, four 15's, HIDs, custom billet door handles, grill, very well kept with all service records and all gm suggested matenice done.
