New member Username: Nick4924Lincolinshire Post Number: 4 Registered: Oct-09 | Can someone tell me if I'm making the right choice when choosing a sub woofer. I am thinking of buying a Sony xplod 1500 watt. model XS-L156P5 15" in a box brand new. Are they any good, will I be disappointed with it.?????????????? PS.. I am open for any advice on choosing an amp if anyone has any ideas Thanks Nick |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2688 Registered: May-04 | Dont buy it. What is your budget? What are you looking for in the sub,SQ,SPL,SQL? What type of vehicle do you have? Do you have a HU and wiring already? Can you build your own box? How much power are you planning on running? |
Platinum Member Username: InsearchofbassYork, Pennsylvania Post Number: 12486 Registered: Jun-04 | x2 Definitely dont buy anything sony. |
New member Username: Nick4924Lincolinshire Post Number: 5 Registered: Oct-09 | Can you be a little more spastic.What dose SQ.SPL. SQL. I'm a bit rusty, its been a whale since I had a car system !! .I have a vauxhall corsa made my own wiring loom 4mm power cable, all ocsigen wire & RCA's too.LG head unit.2800 WATT W 4 Channel V19 CAR MOSFET AMP AMPLIFIER NEW. 2000 watt 6x9's 350 watt 5" door speakers from loudest .com What do you think????????? |
New member Username: Nick4924Lincolinshire Post Number: 6 Registered: Oct-09 | Basically I want the base to thunder like my old car use to about 10 years ago. I no its been a whale.!!! subs and Amp's have moved on quite a bit since then. The rest of the system is fine. |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 120 Registered: Jul-09 | Yea,i would stay away from sony too. How much do you wanna spend? |
New member Username: Nick4924Lincolinshire Post Number: 8 Registered: Oct-09 | £200 on a sub |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2689 Registered: May-04 | Ok I havent even heard of any of your equipment or your vehicle. Im guessing you dont live in the states? Couple things though,your 4 ch amp is not putting out 2800 watts and your 6x9s are not 2000watts. Your 5" speakers probably arnt 350watts either. If you want my advice I would get rid of everything and start over. First get you a good HU(pioneer,eclipse,alpine,JVC,Kenwood) then you should get a decent set of components for the front and a good amp for them. After you do that then worry about the sub. If you want to just add a sub and amp to what you have,I would suggest an Audioque HDC3 or a couple SDC2.5s with the AQ 1200d amp. Get a ported box tuned to 34-40hz you will be happy with the output. AQ is much much better than anything Sony makes. www.audioque.com |
Silver Member Username: JbpittPittsburgh, Pa. Usa Post Number: 122 Registered: Jul-09 | If you want to run a single 15 you could go with this. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=14957 What amp are you gonna be using for the sub? |
New member Username: Nick4924Lincolinshire Post Number: 9 Registered: Oct-09 | .2800 WATT W 4 Channel V19 CAR MOSFET AMP AMPLIFIER NEW. 2000 watt. |
Gold Member Username: JoebruceTC Sounds/DLS Post Number: 2691 Registered: May-04 | I quit |
Bronze Member Username: TedsprogzNunya, Florida US Post Number: 76 Registered: Aug-05 | that makes NO sense...2800 or 2000?? no brand name or model?? come on man use your head... |
Gold Member Username: DuckaShelby Twp., MI United States Post Number: 1208 Registered: Jan-08 | Nick Clark The profile that you have requested no longer exists. The user who created this profile has been deleted from the system. ^did Paul ban him? This thread if chalked to the brim with fail anyway. |
