Clarion radio 2nd serial number?
Username: Robertson1983
i cant find the serial number i need to got the code for my radio? i can only find the cl040220838354 number.should i open the casing on the radio to look for the one i need?
Username: Regrooster
Post Number: 1748
It should be on the outer casing only.
A label with two barcodes , the lower one beginning with C7000000+ + + +
see example here
(ignore the Davidson Electronics watermark)
http://www.davidsonelectronics.co.uk/images/Serial_Locate/ClarionBarcode.jpg
Only around 20% of Clarions will have this number.
If not you will have to try your Main Dealer or a Decoding Service
its defo only got the one serial number on it! not the one i need tho. thanks very much for your help anyway.
