Big box for extended cab ranger
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2748
We junked the mini van, wasn't worth messing with. Sold my grand prix and I'm buying an 1999 ford ranger extended cab. Anyone ever did a big box for one? I want a box I can install/remove without removing my front seats. my truck has the xlt package, with like a split bench but looks of bucket seats (fold up arm rest in the center for 3rd seat). No 3rd door. So anyone have any info or dimension (LxWxH)?
Username: Tedsprogz
Nunya, Florida US
Post Number: 73
Yes i have a 97 Mazda b4000(same a a ford ranger) you can easily build a ported box for 1 15 the max is 17 Depth x18 Height x 42 Wide. internal is 6 cubic feet before speaker & port displacement.i know that a little much for most 15's but you can always go smaller. hope that helps
Username: Tedsprogz
Nunya, Florida US
Post Number: 74
you could wedge it also so you can tilt your seat back...its kind of annoying with those dimensions...it would be a way to cut down the cubic feet if 6 is too much also.
Illinois Braaap MX
Post Number: 2751
I'm going with an 18". I need 6cf gross at the very minimum. Got some dimensions from a member on another forum for this truck. Gonna build a cardboard fitbox today and make sure everything fits.
Username: Snowball123
West Allis, WI
Post Number: 2967
Even taking out the front seat isnt too hard. All you have to do is take out a couple bolts. Should be easy.
Illinois Braaap MX
Post Number: 2755
I would prefer to not have to remove it, to make it easier to take out on a moments notice. But if it comes down to that it isn't a big deal.
West Allis, WI
Post Number: 2979
Well I tried to fit the biggest box I could fit in my dakota and it fits through when the seats are fully folded forward.
Username: Kingandsons07
TEAM NEBRASKA Lincoln,NE
Post Number: 727
i gots to see this an 18 in a ranger
West Allis, WI
Post Number: 2981
http://www.caraudioclassifieds.org/forum/showthread.php?t=14525
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 7119
we did an RE SX 18 in my friends small mazda pickup.. same thing as the ranger
