Stuck between two box designs
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6695
one is a CRX style box.. and the other is built more to specs
4.081 cubes with 4 4" external at 18" long @ 39.04hz .. external aeros
(ports will likely get shortened as testing and tuning comes into play so tuning will go up)
-or-
6.154 cubes.. internal aeros .. 4 4" and 6" long .. 46.51hz for spl.. 18" long for daily @ 32.65hz
(tuning could change if the car peaks lower than 56hz)
Username: Frkkevin
Post Number: 6696
subs/ two RE SX 15"
car/ Subaru Legacy Wagon
Username: Frkkevin
Post Number: 6697
and yes im aware of the first box being not built to sub specs.. was wanting to test out a crx stle.. never messed with them hence why i posted
Username: Frkkevin
Post Number: 6699
Username: Van_man
Boston South, MA
Post Number: 4840
box 1.
Smaller box,
more power,
And i bet your car peaks in the high 40's, low 50's
Username: Turnmat
Racine, Wi
Post Number: 1032
I would go with the 2nd box. Even though the first box would be fun to play around with.
Username: Frkkevin
Post Number: 6700
im thinking low 50s.. but its a wagon so it may be lower.. seems larger cars peak lower.. of course each car has two peaks
amp will be the SS6500d @ 0.5ohm for now
ive just never messed with a crx style.. i don't think ima have time to build before the show tomorrow so i may just mod the box thats in there and tune it lower..
im going to sweep a sealed 15 and find the note with everything in the car.. should put me in a close target range to tune the new box too
Username: Van_man
Boston South, MA
Post Number: 4841
sounds like a plan.
My van peaks at 45...
