Alpine or rockford???
Username: Tdwpgtp
Cleveland, Ohio
Post Number: 36
hey everyone no one wanted to help me in the AMPS section so im gunna post in here. if you had to choose between a alpine mrp-f450, and a rockford fosgate 501x(older model 125x4 RMS) both in good working and physical condition, which would you pick?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10515
Both good quality amps. I'd get whichever costs less.... unless the rf is used and the alpine is new then get that.
Username: Tdwpgtp
Cleveland, Ohio
Post Number: 37
both are used. i do know that the RF does not have a frequency knob, it just has the hpf/lpf/full. and do you think that since the RF is an older model that the ratings and quality may not be up to todays standards?
Username: Nd4spd18
Philadelphia, PA
Post Number: 10516
If it doesnt even have an adjustable filter then definetly get the alpine. That says something about the quality of amp it is.
Username: Jordon32990
Hagerstown, IN
Post Number: 91
I own an Alpine mrp-f450 and it has served me well. Powered two 12" MTX 6000's with it. Good amp.
Username: Insearchofbass
Post Number: 11488
Go with the alpine.
Username: Tdwpgtp
Cleveland, Ohio
Post Number: 38
do u guys think the RF does rated power? it doesnt say CEA approved i dont believe, but then again its a pre 2006 amp so idn if they had that back then. idn what year it was made exactly tho...
Post Number: 11501
Go with the alpine.
Username: Tdwpgtp
Cleveland, Ohio
Post Number: 39
ha alright. its 100 bucks used. worth it i hope..
