Crewman
Username: Dmd23
my mate jst bought kicker CVT 12 inch for his crewman which is gona be put under the rear seats. he has a kicker 750/350rms amp to power the shiznettt.. hows it gona sound?
Username: Ctmike
Ct.
Post Number: 6675
like shiznett.
Username: Rideredder
Cornell, IL USA
Post Number: 1616
^^LOL
Username: Dmd23
na seriouslyyyy
Username: Dmd23
yalla emshi sharmuta
Cornell, IL USA
Post Number: 1617
Username: Dmd23
whats it gona sound like :-) kicker CVT 12 inch 400watts rms wif enough power going to it. in a crewman. will it be decent bass?
Cornell, IL USA
Post Number: 1618
Depends on the install.
What is a Crewman by the way?
Username: Dmd23
holden crewman, 5 seater ute
Username: Ctmike
Ct.
Post Number: 6676
no one can answer your question. will it be enough bass? that varies from person to person. and asking how it will sound? again, everybody likes different subs. what one person thinks sounds good can sound like shi_t to another.
why not install it and listen to it yourself.
Username: Dmd23
Post Number: 7
"decent bass" in my view is being able to hear the lows of songs such as "gangsta rap made me do it - ice cube" and for to shake the car up a bitt. i know its deffs gona be an improvment obviously but i just wanted to know what to expect from these subwoofers
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 6544
don't expect much, especially from under a seat.
Username: Hittin1
TEAM REVOLUTIONLake Charles...
Post Number: 3256
Not a bad sounding shollow mount sub, if you are running it sealed in about .5-1^3 of airspace it should hit in the mid 130's on rec. power.
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2936
This.
Username: Hittin1
Post Number: 3257
I've seen 2-12" cvts get better numbers than 2-12" cvr's in same sealed box. .3 dB better iirc.
Username: Dmd23
Post Number: 8
the seat is a fold up nd down seat which had a plastic tray underneath for storage.. the plastic tray was removed which left more than enough space for the subwoofer aswell as open area around it
Username: Frkkevin
Post Number: 6545
if you want anything worth a damn fiberglass the whole enclosure under there and use all the room available.. you will have more options
.. another choice doing the same fiberglass box is to put the seat on risers.. taller box.. deeper subs
Username: Dmd23
Post Number: 13
picked up the sub today placed it under the rear seat, it all fits. his thinkin of getting 2 one for each side of the rear seats and chucking the amp in the tray of the ute. tested the sub in my mates car sounds good, wasnt even at its peak power.
Username: Drant19
DUB-C, TX
Post Number: 1636
"wasnt even at its peak power"
peak means nothing
RMS is whats important
Username: Dmd23
Post Number: 14
walla thats wat i meant it was at 100rms its rec max is 400rms but i have heard that they can easily handle 500
Username: Ctmike
Ct.
Post Number: 6682
where's the pics of the solo xs' and warhorses'?
Username: Dmd23
Post Number: 16
ct mike, eat a dick :-)
Username: Ctmike
Ct.
Post Number: 6710
why you put a smiley after saying " eat a dick"? that what you like to do you hom_o? whatever floats your boat, but please keep what you and your mate do downunder off ecoustics, this isn't a ga_y forum, it's a car audio forum.
with that said, pics or leave, douchebag.
