Well I have had my subs in my truck for a total of about a month. Now I want louder. i'm not sure if I can really do much more seeing's how I drive a ranger but here goes.
Would there be any single tens that would be louder ( I know broad term) then 2 10' RE SRs?
My specs Orion HCCA1200D My box is 1.7 cubes ported to 34 hz.
Or should I be content with what i have. I'll have around 200 to spend on a sub. Thanks
If you want louder with a compromise on the low end a little go with a kicker l7 2008 series The 2008's are supposed to sound better than the old kicker l7's and the weak corners are addressed in the 2008's also.
