Looking for decent budget speakers
Username: Vivi2000
Owosso, Mi
Post Number: 135
I recently purchased some new subwoofers and now my current speakers can't keep up with them. I have a budget of about $200-$300 for the speakers, amplifier and wiring. My front speakers are 4x6 so I was thinking about getting 5.25" speakers so it would be easier to install than 6.5".
I currently have a Pioneer DEH 3000IB headunit, some $40 pioneer 4x6 coaxial speakers and 2 RD audio classic subwoofers powered from a hifonics BXI1206d.
I listen to a lot of metal and hard rock, so I would like a lot of midbass so that the bass kicks are much more pronounced.
I have not heard any other aftermarket speakers, so i do not have any experience with them. Also my current ones are powered from my HU which gives 22wrms x4, they do not get loud enough for me.
I have a 2001 chevy cavalier, it came with coaxials stock, so there is currently no mounting for tweeters.
Would I be better off with a set of components or coaxials? And if i do decide to get components how hard would it be to make a custom mounting spot for them?
Username: Vivi2000
Owosso, Mi
Post Number: 143
Any thoughts?
Username: Basebalz13
Moneta, Va Usa
Post Number: 1200
components for sure!, are you willing to get a amp to also run the comp set with? or break that 200-300 dollar budget to get both a amp and nice set of comp sets?
Username: Vivi2000
Owosso, Mi
Post Number: 145
I am willing to go up to around 300 or 350 for amp speakers and wiring.
Username: Lnhiv
Mesa, AZ USA
Post Number: 15
You can fit woofers up to about 2.75" deep behing your doors without a problem, and just drilling a hole to do some flush mounts tweets is easy, so I'd say go with some components.
The sound difference is more than worth it.
Moneta, Va Usa
Post Number: 1209
hmm well on that budget im currently thinking these
http://www.vertexaudio.com/store/pc/viewPrd.asp?idproduct=7&idaffiliate=2
now talk to exige.....he's got much better pricing on these. they're a great budget set though. he's on here as Exige Audio. i think his email address is mike@exigeaudio.com.
here's a few good amp choices that come with a full warranty
http://www.crutchfield.com/p_098CO6002/Orion-Cobalt-CO600-2.html?c=3&tp=115&avf= N
and this will work well bridged
http://www.crutchfield.com/p_500MRPF300/Alpine-MRP-F300.html?c=3&tp=115
Username: Steve_tallica
you might also want to look into db drives stuff, its pretty good, im pretty sure their db line fits in ur budget
Username: Vivi2000
Owosso, Mi
Post Number: 147
Thanks for the help, ill look into what you guys said.
Also dont I need a 4ch amp to run 1 pair of component speakers? I thought I rememberd reading somewhere that you put the woofer and the tweeter to seperate channels.
Moneta, Va Usa
Post Number: 1218
nooo when running comp sets ur Mid bass and Tweeter connect into Crossover box then from the crossover box to the amp, if you use the 4 channel amp you have to bridge the amp so it is a 2 channel amp anyways
Username: Exige
CDT, Audiopulse Dealer
Post Number: 764
When running your comp set active, you would need a 4-channel amp. This is more advanced and would require you to determine crossover points and slopes yourself. If you don't have any experience with this, definitely stick with the passive crossovers and a 2-channel amp. If I can be of any assistance or if you have further questions regarding active vs. passive (or other technical questions), feel free to email me at mike@exigeaudio.com
