New member Username: TripphxcPost Number: 1 Registered: Mar-09 | well this is what im most likely deciding on. 1) One 15" bl 2)saz-15000d 3)The big 3 upgrade 4)This amp kit [URL="http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0"]http://www.knukonceptz.com/productDetail.cfm?prodID=KFX-PK0[/URL] 5)RCA Cables [URL="http://www.parts-express.com/pe/showdetl.cfm?Partnumber=181-656"]http://www.parts-express.com/pe/showdetl.cfm?Partnumber=181-656[/URL] Does this sound good? and then all i would need is a BOX. how would 1 15bl even sound in a ported box? this is going in a jetta |
Gold Member Username: BonhamdTraverse City, MI Post Number: 1817 Registered: Nov-07 | great setup i would go ported for sure. do you have any wood working skills? |
New member Username: TripphxcPost Number: 2 Registered: Mar-09 | well i have always helped my dad build stuff like sheds and stuff... and where i work we work with wood and stuff.... also, would this sound good with any type of music or would it sound better with like rap/hip hop more then... metal and hardcore? thank you |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 908 Registered: Jun-06 | i dont think the BL is gonna take that 3kw+ daily...might wanna step upto the BTL |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10099 Registered: Jul-06 | His amp is 1500w RMS which is perfect for a BL. |
Gold Member Username: SomedonniedudeIllinois Braaap MX Post Number: 2436 Registered: May-07 | He is pushing 15,000w m.s. look at the amp he is using! The all new SAZ-15000D If you are looking for something so sound good, I'd pick the Fi Q over the Bl, but I'm not sure how the Q would handle that power, I've never tried or heard either sub. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10104 Registered: Jul-06 | The BL will sound fine. If you want great SQ, then yeah, get the Q, and it has to have the BP option to handle that much power. |
New member Username: TripphxcPost Number: 3 Registered: Mar-09 | I dont know what SQ means or what it is for.... and the bl has to have the option of BP...? |
Gold Member Username: BasssquaredKansas Post Number: 2499 Registered: Nov-06 | SQ= sound quality |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10106 Registered: Jul-06 | Q needs the BP option for that much power. |
Gold Member Username: BernymacPhnom PenhCambodia Post Number: 4608 Registered: Sep-04 | how would 1 15bl even sound in a ported box? it will sound like boom booom booom extra booom. |
Gold Member Username: TejcurrentPost Number: 1772 Registered: Apr-07 | In a good ported enclosure that sounds like an excellent first system. I would consider upgrading your factory battery or adding maybe an extra depending on what you have for your mids and the size of your alternator. A |
Silver Member Username: Dsmith07NC Http://com4.... Post Number: 909 Registered: Jun-06 | damn too much herbs i read it wrong earlier lol |
New member Username: TripphxcPost Number: 4 Registered: Mar-09 | So if i were to upgrade my stock battery would i be good? or would i also have to upgrade my alternator? what kind of battery would i want to buy in order to replace the stock one? i hear people saying red top or yellow top where do i go to buy one? |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10109 Registered: Jul-06 | No no no to anything optima. That is the equivelent of kicker subs haha. For 1500w an alternator upgrade may be in order. Alternator is the power source, adding batteries does not give you the ability to draw more power and hold proper voltage while driving. Combined with a proper alternator a good battery does help though. Odyssey, kenitik, powermaster, all are good. DB Electrical or MCR for alternators. And don't forget big 3 wiring must be done with an alt upgrade. |
Platinum Member Username: Nd4spd18Philadelphia, PA Post Number: 10110 Registered: Jul-06 | One thing I forget to consider, the SAZ-1500 is very efficent compared to most amplifiers, so you may or may not need the electrical upgrades. |
