Bronze Member Username: Notw000Post Number: 12 Registered: Feb-09 | Hi. im bout to start cutting for a box holding 4 12's and i need to know whether the rockfords will sound better ported or none ported. the box will be 7.1cuft after potential port displacement. if ported i will make a slot port as follows: http://i532.photobucket.com/albums/ee322/notw777/jaybox.jpg |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7299 Registered: Mar-04 | Before you waste your MDF, what vehicle do you have? |
Gold Member Username: JtownTexas Post Number: 3632 Registered: Mar-07 | before you waste your MDF, I don't think 1/4" will be enough as far as integrity of the wood goes. also, I'm not sure the basket would clear the top and bottom, but I'm not sure on that. |
Bronze Member Username: EricmbWaycross, Ga. United States Post Number: 37 Registered: Nov-08 | the stage 1 series do not sound good really in any box i've heard them in. Though i do think they sound better in a sealed rather than a ported.. and i wouldn't use 1/4in. i would at LEAST run 1/2 on anything i built.. but that's totally opinional |
Bronze Member Username: Notw000Post Number: 13 Registered: Feb-09 | i will be using 3/4in MDF and the box is for a friend of mine(i dont like rockford anything). he already has a box with mostly the same specs except for the port and minor changes in the length and height. the measurements shown on the drawing are actual air space specs after 3/4in wood displacement. the real point here is whether the p1's will sound better ported or not. the box is going into the trunk of a mercury marquis. |
Gold Member Username: SouthernrebelMonroe, Louisiana Team Audible... Post Number: 7300 Registered: Mar-04 | Again... WHAT VEHICLE??? What you think at "minor" changes may be far from it. You need to build a properly designed box, not just something that fits in the vehicle. You are wasting your time it you do not. |
Bronze Member Username: Notw000Post Number: 14 Registered: Feb-09 | MERCURY MARQUIS |
