1/0 Wire
Username: Mendonmafia
Post Number: 1726
Is that monster wire on ebay $60 for 25' a legit deal?
That sounds like a pretty good price to me but im not sure.
how bout that stuff thats $90 for 50 feet. it says it has 3200 strands and the monster dosnt say how many strands.
whats the number of strands mean? does less strands mean less current? Details please?
Username: Jtown
Texas
Post Number: 3620
More strands, more true measure of the posted size. For instance, Paul has/had 1/0 from ED or Raptor, that is really 2ga.
Username: Turnmat
Racine, Wi
Post Number: 889
I am not sure if that is legit or not. You could get some 1/0 from knuconceptz
http://www.knukonceptz.com/productMaster.cfm?category=KLMX%20Kable
Just trying to help you save some $$$
Post Number: 1728
thanks but i already have knu and am not happy with it. the klm wire is only good for 250 amps as well.
i think im gonna buy the monster and give it a shot.
Username: Bonhamd
Traverse City, MI
Post Number: 1742
250 amps is good for 3K - you have an atomic 3K right?
i doubt you will see any difference from just swapping out the wire
why not throw in another run if youre not happy?
Username: Deadrabit
Marionville, MO
Post Number: 1290
just because it is thick doesn't mean its good. look for alot of strands and 100% tinned copper.
i have 21 foot of memph ott guage. is 100% tinned copper. 65 bucks
Username: Cdb004
I got 6 12s
Post Number: 27
xscorpion 1/0 expert link is nice we use it at the shop.
Post Number: 1729
Daniel, i do have an atomic 3k but i plan to run it .5ohms down the road so i want to have a good solid wiring setup. i would run 2 runs but that would cost twice as much ans my amp only has single 1/0 inputs.
Cory could you sell me some?
while im at it i have a quick hypothetical. lets say i am running 10k rms daily and i have a bank of batts in the back and a starting batt up front, and a single 200 amp alt. since i only have a 200 amp alt would it be ok to run just a single run of 1/0 from the alt to the batts in the trunk and the starting batt (grounds too)? and then just run how ever many run i need from the batts to the amp (grounds too)?
Username: Bonhamd
Traverse City, MI
Post Number: 1746
i have a rd3250 and i run it at .5 ohms. i have the same wire knu 1/0 (250A) and have it fused that way
i have never popped a fuse if that makes any difference
i have 2 runs from the front to the back but one of the runs is a ground
Username: Deadrabit
Marionville, MO
Post Number: 1292
if u have a 200 amp alt one run would be ok. 2 runs would be a little better, anything more is kinda a waste.
how long of strands r u talking about?
Post Number: 1730
Ya by one run i mean 2 as in one for pos and one for ground.
So that would be ok then even if i had like 8 batteries and 10k watts to just have a single run of 1/0 (one for + and another for -) running from my alt to my starting battery and then from my starting battery to my battery bank in the trunk? and then having however many runs of 1/0 i need from my battery bank going into my amp(s).
Username: Snowball123
West Allis, WI
Post Number: 2350
hey BLK how much would you sell 12 feet of that wire for.
Post Number: 1731
well from alt to starting battery is about 6 feet then from there to the trunk is another ~17'.
Username: A12voltman80
St. paul, Mn Usa
Post Number: 22
3200 strands sounds like 2G wire not 0.
Post Number: 1732
thanks a lot mike.
Im going to just keep looking for a deal over on ca.com or just buy the monster for 2.4 a foot shipped. its got the magnetic core thing so im guessing its legit monster.
Post Number: 1734
anyone find anything better than monster for under 2.40 a ft
Username: Rideredder
Cornell, IL USA
Post Number: 1555
Knukonceptz 1/0 Kolossus Kable is 5,145 strands. I've seen the Monster Cable and it does look like 2 gauge. Raptor wire is more like 4 gauge.
Username: Okbuynowcom
Do you need some electronic products?
I know some from okbuynow.com
cell phone watch, Hiphone Cell Phone, Hiphone Tri-band TV Phone, Unlocked XPhone , Unlocked XPhone Tri-band, Unlocked XPhone Dual Sim Card , Hiphone I9 , Hiphone I9 Dual Sim Card , Hiphone I9 Quad Band Cell Phone , S689 Tri-band TV Cell Phone, EPHONE M8 , EPHONE M8 Quad Band Dual Card, TV Cell Phone - Bar Phone (Black), 588 TV phone, 588 TV phone Dual sim Dual standby, Super F698 TV Phone, Hiphone XPhone Tri-band, Silver color XPhone , P168S Hiphone , P168S Hiphone Tri- Band Dual Sim Card Cell Phone, Unlocked XPhone Tri-band , Hiphone A6 Quad Band
Username: Tejcurrent
Post Number: 1744
Take 2 dmms and get a friend to help you (easiest way).
Burp your car with one of you checking your voltage in back and one testing up front. If its more than a few 10ths of a volt off I'd add a 2nd run of power and ground wires.
Helped me quite a bit.
Hope that helps.
St. paul, Mn Usa
Post Number: 26
Monster is good wire. Now that its main retail outlets are gone you will see it going for great prices while they try to off load as much as possible.
Username: Deadrabit
Marionville, MO
Post Number: 1293
i am telling u just get either the knukoncepz 0 guage 100% tinned copper or my memphis wire. (my memphis has a few more strands) dont short ur self with cheap wire. i have done that before. if its 17 foot i would run two runs. my alt is a 210 and it is also 17 foot. u could even get some good 0 guage and then a run of 4 guage with that.
snow i already told u! its 8 dollars a foot for u.
who ever else wants it its 63 bucks for 21 foot. its orange
Username: Deadrabit
Marionville, MO
Post Number: 1294
monster is alright wire. i got a lot onsale at walmart for CHEAP! i use it for my speaker wire
St. paul, Mn Usa
Post Number: 27
Monster may have a wall mart line but they sell at ultimate audio, used to sell hi fi buy and CC.
There top of the line is very nice. It will compare to Stingers best.
Username: Deadrabit
Marionville, MO
Post Number: 1295
some one needs to buy my memphis wire
Username: Deadrabit
Marionville, MO
Post Number: 1296
and by the way! the klm u r looking at is NOT 100% tinned copper! they make some that is like 3.75 a foot i think. it will do u a good 300 plus amps
Post Number: 1735
BLK id buy your wire but $3 a foot is to much. im looking to spend $2 a foot.
Welding wire is fine to me. as long as it can handle the current i dont care what it looks like. thats what loom is for.
