Kicker 12" L7
Username: 71_chevelle
Post Number: 143
My buddy bought a Kicker 12" L7 subwoofer and a ZX750.1 amp to go with it but i believe the subwoofer is a dual 2 ohm subwoffer which comes out to be 1 ohm right? so what would happen if he continued and wired the L7 dual 2 ohm sub to the ZX750.1??
Thank you!!!
Username: Prozack52
Cincinnati, 2-audio puls...
Post Number: 483
if u wire the sub positive to positive neg to neg that would be 1 ohm and nothing would happen to it... it would get its required amount of rms power
Username: Prozack52
Post Number: 484
wait is the 750.1 1 ohm stable i forget
Username: Prozack52
Post Number: 485
if it is 1 ohm stable ur fine
Post Number: 144
I do not know if it is 1 ohm stable online it just says 2 ohms
Username: Caraudioislikecrack
Post Number: 34
all the kicker zx mono amps are 2ohms not 1 ohm stable
Username: Snowball123
West Allis, WI
Post Number: 2266
get the Dual 4. Dont run the Kicker at 1 ohm.
Post Number: 145
Ok thank you snow i'll let him know
Username: Nd4spd18
Philadelphia, PA
Post Number: 9887
Won't work, that amp is 2 ohm stable.
Either get a different sub or different amp.
Post Number: 147
what would happen if he decided to hook them up?? would it ruin the amp or the sub??
Username: Drant19
DUB-C, TX
Post Number: 1423
"Either get a different sub or different amp"
get a different sub! how much is your budget for a sub. the 750.1 is a good amp that underrated.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9891
Amp will go into protect or the amp will be toast.
Post Number: 148
Oh ok ok =]
well its not for me its my buddy's car and he was still wanting to put them together so i was double checking what would happen if he did it. I'll be sure to let him know to get the dual 4 ohm kicker L7 instead...even though he's already bought the dual 2 ohm haha poor guy! oh well it's a learning lesson for him!!
Thank you everyone for your help!!! =]
Username: Nd4spd18
Philadelphia, PA
Post Number: 9916
You could help out even more and tell him to get a different sub..... L7s suck.
Post Number: 152
hahaha ok =]
what do you suggest i tell him to get?
he's got the kicker zx 750.1 @ 2 ohms amp and he's working with about 1.32 cubic feet in his trunk...he's got a '91 camaro = not much trunk space hahaha
Username: Nd4spd18
Philadelphia, PA
Post Number: 9920
A Fi SSD, something from RD, even a CVX is he really wants kicker.
Post Number: 154
Alright i'll throw those at him and do you have a link i may be able to find the Fi SSD subs?
Thank you M.S.!!!
