Looking for tweeters
Username: Shade
Moxee, Wa U.S.
Post Number: 833
Hey, maybe u guys can help me. I've searched for a while now and am looking for a good set of highs or 2 pair of highs that can be crossed around the 2k mark..or 2.5k. any help is appreciated. I'll be pairing them with ID OEM 6.5's.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9913
CDT ES-010
You didn't give a budget :-)
I'd recommend some DRT-25 though, they are resonable priced.
Username: Shade
Moxee, Wa U.S.
Post Number: 835
i found those CDT ES-010 for like 249 and they can cross at 1.5kz
and asfar as the DRT-25...i coudnt' find any specs on them asfar as crossover points.
Username: Nd4spd18
Philadelphia, PA
Post Number: 9923
http://www.cdtaudio.com/custom_components_08.htm
Click whatever speaker you want for data sheet
Username: Shade
Moxee, Wa U.S.
Post Number: 836
nice... so they both can crossover at 1.5.
do u have experience with both of them or either of them?
tweets iv'e used soo far.....pg rsd, type R, type X, and JL from a XR set.
how would the drt 25's compare?
Username: Nd4spd18
Philadelphia, PA
Post Number: 9938
I personally run the DRT-25. And they beat all the ones you just listed... except I haven't heard the JL.
I would love to try out the ES-010 since I'm told they are even better, but haven't got the chance to.
Username: Shade
Moxee, Wa U.S.
Post Number: 837
gotcha...thanks.
i think i'll order the drt 25's
