Wiring to correct ohm load.
Username: Vivi2000
Post Number: 90
I currently have 2 4 ohm dvc subs and i need to wire them to a 4 ohm load. The thing is i cant just wire them like this
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
I have them in seperate sealed enclosures until i get time to build my own for them. Would I just wire them each to an 8 ohm load and then treat each enclosure as if i have 1 8ohm svc in it and wire it to 4 ohms?
Username: Basssquared
Kansas
Post Number: 2445
you would wire each one to 8 ohms and then pos to pos and neg to neg that would be correct Jon.
Username: Basebalz13
Moneta, Va Usa
Post Number: 971
x2
