Getting new subs... any sugestions?
Username: Robert_is_a_g
Fort worth, TEXAS USA
as of right now im pushing 2 12 inch p3s with a downward fireing sealed box
and was thinking about ubgrading to the JL w7s with a vented box and maybe a new amp, im rocking a 900 watt sony xplod monoblock
any sugestions?
Username: Blazerboy
15 $$D wangi...
Post Number: 616
Where do we start?
How about you shoot a budget for the system at us. We will hook ya up.
nothing over the top just som recreational bass but not crappy maybe in the 1500 department
Username: Blazerboy
15 $$D wangi...
Post Number: 617
Rockford is not known for their subs, and Sony is not know for...well anything. With $1,500 to work with there are a ton of great sounding options.
Few more questions:
How much RMS (watts) did you want to run?
How much space do you have to work with?
Do you want more sound quality (SQ) or loudness (SPL)?
Is the $1500 for an amp, wiring, box, and subs? Or did you want to put some mids and coaxials in as well?
trunk space is not a problem, i have a ford excursion and i was thinking i would like just clear sound maybe a little louder than what i currently have
i dont think im gonna put in anything else but the subs and amp and whatnot
Username: Blazerboy
15 $$D wangi...
Post Number: 619
Two RF P3's do 1000 RMS I believe.
If you want to stay around 1000, the first sub that comes to mind to me is a 15" Fi BL ($400).
Give it ~4 cubes and tune it to ~30-35 hertz.
A hifonics bxi1606d ($250) is a pretty common amp to power this sub.
There are a bunch of other options though.
Some good brands to check out that come to mind would be:
Fi
Re
AudioQue
Revolution Designs (RD)
And dammit stay out of best buy!
i was talking 1000 watts per sub, what should i do in that case?
and eff best buy
Username: Blazerboy
15 $$D wangi...
Post Number: 620
Don't get caught up in wattage. RMS is the rated power, and it is what everyone that knows anything about car audio goes by.
Yes your p3's advertise 1000 watts, but that is really 500 RMS a sub, so 1000 RMS total.
The Fi Bl does is a suggested 1000 RMS sub, but can do more. 1600 RMS is a common number to run them at, and if you get power options like flatwind coil, there is no way your blowing them.
Once you get in the 2000+ RMS range you have to start thinking about upgrading your battery and alternator, so keep that in mind.
Also remember that a good system is nothing without a good head unit. Pioneer, Alpine, and Clarion.
im good im rocking an eclipse 5500
why not rhe w7s?
and also my car is desiel so it runs on 2 bateries anyways
Username: Blazerboy
15 $$D wangi...
Post Number: 621
Not many people suggest JL because there's better out there for the money. They are a good sub, but the brands I recommended will get louder and sound better doing it for the same price, or even less.
Username: Rovin
1 15 = 149.5 DBs ...Trinidad & T...
Post Number: 14680
imho RF p3s r not too bad but i think u shud use a better amp on them , also if u have a crappy box obviously they will sound like chit ...
