Gold Member Username: HdubbTeam Revolution Post Number: 3989 Registered: Nov-04 | i got a audiocontrol EQX today from him. its nuts lol. neer seen something with so man knobs LOL. thank you kevin. i think ill learn up on it and drop it in teh wifes ride. thanks again bro. its se.xy. ![]() |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3879 Registered: Nov-05 | eqx* very nice |
Gold Member Username: Van_manBoston South, MA Post Number: 4481 Registered: Mar-06 | pics? |
Gold Member Username: HdubbTeam Revolution Post Number: 3990 Registered: Nov-04 | thats what it says. lol ill try and get some pics up today ![]() |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3881 Registered: Nov-05 | hehe ![]() |
Gold Member Username: HdubbTeam Revolution Post Number: 3992 Registered: Nov-04 | http://www.caraudio.com/forum/showthread.php?t=357197&highlight=audiocontrol+eqx |
Gold Member Username: Hittin1Lake Charles, La. United States Post Number: 1966 Registered: May-07 | how much shipped to 70615? lol j/k sweet gift, congrats |
Diamond Member Username: BestmankindPost Number: 23103 Registered: Oct-05 | hunter, you might want to use a long rca cable and power cable so you can sit in your front seat with that unit to adjust. after you find your settings, you can then put it back in the trunk. also use a piece of paper and jot down your settings so you can refer to it incase it gets changed by accident or something. its a b!tch changing the setting and then listen in the car then go back to the trunk and set it again and listen again, etc..... if you are gonna mount it somewhere near by the front then forget what i said. ![]() |
Platinum Member Username: Rovin1 15 = 149.5 DBsTrinidad & T... Post Number: 14553 Registered: Jul-05 | ^^good idea from chad man what a sweet azz gift to get ! ... |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 19341 Registered: Jun-06 | The bar has been raised fellas. Awesome gear hunterw. This is really catching on. ![]() |
Platinum Member Username: Nyyfan13Http://lowdo... Join My User... Post Number: 10888 Registered: Jul-06 | Wow, sweet gift man. Glad you got hooked up Hunter. Sweet sh1t Kevin. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3882 Registered: Nov-05 | when i had my eqt's i just kept sticky notes on them with each knob setting... and those had a couple more knobs. |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6007 Registered: Nov-05 | Its the old school one.. no one wanted to buy it from me so i figured it would make a great SS gift. I bought it off diymobile a while back and never used it since i went ahead with the h701 so if for some reason it does not work let me know and ill send you something else |
Gold Member Username: FrkkevinTeam DLSSuperNatural... Post Number: 6008 Registered: Nov-05 | oh btw i hope it made it in ok shape lol.. was in a hurry at the post office and i ran out of packaging at the house so all i had was a box and whatever that had at usps.. which was bubblewrap lol |
Gold Member Username: Th3pwn3rI compensate... Post Number: 9081 Registered: Jul-06 | "when i had my eqt's i just kept sticky notes on them with each knob setting... and those had a couple more knobs." Unless you listen to the exact same source over and over this wouldn't make much sense. Not everything is recorded exactly the same so depending on what you like your music to sound like ex: a flat response then you'd be adjusting all the time. |
Gold Member Username: HdubbTeam Revolution Post Number: 3994 Registered: Nov-04 | cool thanks kevin. it looks just like it did in your pixels ![]() ![]() |
