RE - 2 12" or 1 15"
Username: Skateguy92
Post Number: 44
I got a custom box made for my expedition for a couple 12's. I kinda wanted to keep it because it looks nice and I spend money/time on it but I can always use it later I guess.
Anyways... I have a hifonics brutus 1500w (ya ya i know) and I was running two 12" type-R's. I want to upgrade and was originally gonna use two 12" RE SE's.
Or I found a new RE SX 15" but it is a D4... So from my amp at max it would be seeing 1000w most likely 900ish but it would be clean 2ohm power at least.
So, I was gonna ask for a few opinions on what to do. Oh and the budget is around $300-350
Username: Logan__tille
Post Number: 9128
http://cgi.ebay.com/2-RE-AUDIO-SE12D4-12-SE-WOOFER-SUBWOOFER-SE12-D4-pair_W0QQit emZ200283081579QQihZ010QQcategoryZ18805QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Username: Loudon
Post Number: 2821
ud be lucky to see 1k after rise and all other components ...
go with a pair of lower rms subs if u have the space they are more efficient on lesser power
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14482
unless u get a bigger amp i dont think new subs will sound much louder than what u have now ...
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2178
Do you want to go louder or better sq? or both?
Post Number: 47
both, I think ive got my plan figured out for my truck. Ive been sold on the RE SE woofer, so im gonna grab two of those for now and I plan on adding two more here in a few months around tax returns and a HO alt with 2500rms. Should get decently loud and sound really good.
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5989
i would not run two RE SEs on 2500rms.. if you plan to get that much power get the SX now and another later.
you will sacrifice a little SQ
Username: Rovin
Post Number: 14495
^x2 ...
Illinois Braaap MX
Post Number: 2190
I think he's planning on running 4 total in the end. 2 now+2 later.
4 of those in a truck would be more than just descently loud. That would be an awesome daily setup imo!
Username: Rovin
Post Number: 14497
oh ok didnt know that - well then he can use those SE's but watch ur vol level - thats what im doing since i also have 2 10s SE's dual 4ohms running off my orion 2500d so i had to control the output by turning down the vol level on my cross over ... what i later did was wire the subs to 4ohms so it gets 1200wrms from the orion which im satisfied with ...
Username: Skibum12189
Cleveland
Post Number: 3021
you could buy my 15" tc-3000 dual 2 ohm for a real nice price....
Username: Surferdude9371
Get loud or go home....
Post Number: 1560
when did logan come back did i miss something?
Username: Frkkevin
Post Number: 5992
I am also running a pair of RE SEs.. great subs.. no where near the output of my old SXs tho.. much better SQ on the other hand... still get decently loud
Post Number: 48
yup, just two for now and then two later around tax returns
I think it will make a pretty nice DD.
