NEW build suggestions
Username: Teamrevolution
ATLANTA, GA USA
Post Number: 461
Well in 2008 i did
6 15" sonance sealed
2 15" alpha
2 15" hw
3 15" hw sql
3 15" alpha
4 15" alpha
2 18" elite spl
2 18" alpha
I have 10 batteries in the back, 1 in the front two mechman alts that do 180+ at idle , had 3 but gas milage sucked.
I was thinking two d9's with four 15" HW's with 65mm tall coils and two spiders tuned to 36-37hz.
what do you guys think?
I am going to trim this system in and keep it for a while so i want to make sure it is good.
If not the hw's i was thinking Alpha MAX with same coil setup.
My alts sit at 14.9 hot so i will get 6k+ out of each d9.
I am going to use a new 3 way comp set in the front " imperial series" and Alpha comps in the rear.
Or maybe something else. If you got any ideas let me know.
truck pics
ATLANTA, GA USA
Post Number: 462
Username: Deadrabit
Marionville, MO
Post Number: 1129
how big of a difference in the gas milage did each alt make?
i am sure what ever u do it will be awsome
Username: Wickedbass
Nashville, Tn
Post Number: 195
I think the four HWs and some d9s would be sweet.
Wish I had room for some 15" HWs, but not even close.
Diamond Member
Post Number: 23050
+1 wickedbass. i was thinking the same thing.
btw steve looks like you need to wash your car and use some clay on it.:-) detailing my car is my new hobby.
ATLANTA, GA USA
Post Number: 463
I wash it all the time, I have to keep that candi paint clean, lol
Plus when its dirty the 12 diff color flakes don't come out as much.
Diamond Member
Post Number: 23051
haha nice.
the dual spider hw will rock your car. espcially if you have 4 of them.
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3455
How about 6 15" HW SQL's in a ported isobaric box with 3 5750s or 3 HW 9.0s. Clamshell box with subs up and port back... With the isobaric boxes ive built in the past you gain alot of lows and with 6 of them the SPL will be crazy.
Username: Mixmastaspig
Team RD, Canada
Post Number: 1934
That Hw swt up will be nuts Steve!
Any info on that 3way set yet.... :-)
Username: Somedonniedude
Illinois Braaap MX
Post Number: 2200
What about something with those elites? not the SPL ones, the newer sq oriented ones (I think). I don't ever hear much about them on the forums. 8 12" Elites on 2 D9's strapped @ 1.5 ohm? (but I guess you could probably have the subs built with what ever vc you want since you own the company lol)
Username: Hittin1
Lake Charles, La. United States
Post Number: 1864
What are the chances of doing an odd number sub setup? Just for sh!ts and giggles, or even trial and error? Just throwin it out there. lol
Username: Denali_on_22s
Post Number: 6269
is none of the above an option?
