2003 Durango System
Username: Diligenthunter
Time to start the audio portion of my Durango.
Im looking at getting
1x Rockford Fosgate T215D2
1x Rockford Fosgate T1500-1bd
2x Alpine SPX-17REF
1x Rockford Fosgate T600-4
And a Sony CDX-GT920U head unit
I also know i need to get a new battery but have no idea at what power level.
Also to upgrade the wiring from the alt and the grounds but what else?
Have about 3000$ to play with , but that does not mean i have to spend that much.
Looking sound quality first then just plain loud.
Its pretty obvious I'm new to this, just looking for some friendly help.
Username: 04redmach1
Es DEALER, GA USA
Post Number: 2447
If you are looing to SQ, I have to say wrong sub for sure. I would also look at the Eclipse headunits in your case too. I would HIGHLY recommend the Eclipse CD7200 :-)
http://www.eclipse-web.com/cd/cd7200overviews.html
As for sub, you may like the Sq from the RD sonance series subs. We usually par them with a RD 1000.1.
http://www.rdaudio.net/sonance/sonance.htm
http://www.rdaudio.net/rd1000/rd1000.htm
Kevin
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 493
i have a eclipse 3200 and i luv it. and i have a 18" rd audio sonance and i love that to so much i couldn't sell it. they sound great and get loud to. i have mine in a 4 cubic foot box sealed. i was powering it with a RD1000.1 but the amp fried thanks to my alpine 9881.
Any where in particular to buy from?
Es DEALER, GA USA
Post Number: 2448
Email me James, I can help you if interested.
Kevin
lowhz01@yahoo.com
email sent
Username: Nd4spd18
Philadelphia, PA
Post Number: 9021
All that stuffs pretty bad except the RF amp
Kevin should be able to set ya up with some good stuff
