2001 toyota corolla firewall?
Username: Greenrocket
where is it???
i spent over an hour looking for a port for my amp wire?
any help
thanks
Username: Nd4spd18
Philadelphia, PA
Post Number: 9031
drill + bit = hole
Problem solved. Usually there is not an existing hole big enough.
Username: Faroutdesign
St.ptersburg, Florida Usa
Post Number: 69
look under carpet on drivers side from what i remember theres a punch out or rubber bushing. run wiring in channel of frame. dont bottom out car. ok!
