Free air subs
Username: Hightecredneck
I have a standard cab full size truck but don't want to sacrifice room and comfort by adding a box behind the seat so instead I'm looking for a good sub that works well without an enclosure, does anyone know of any ?
Username: Insearchofbass
Post Number: 10791
With free air subs you still have to have a baffle to divide the front wave from the back wave. And making sure that its air tight is important.
Post Number: 10792
If you want a small box sub that has good sq and decent output go with an image dynamic idq 12 v2 (.55 cubic feet sealed plus .07 for the subs displacement. (.62)
Username: Nd4spd18
Philadelphia, PA
Post Number: 8879
Hahaha no such thing as "a good sub that works well without an enclosure"
Username: Crayola0
Portage, Wisconsin
Post Number: 2519
its like asking what kind of fish does best without water
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 687
Where would you put it. The reason I ask is because you would have to completely block the front off from the back... In a truck you would pretty much have to build a box to do that... Unless you plan on doing some chopping, but it wont be worth it to chop up your truck for bad bass.
You could also look into shallow mount subs if you really wanna conserve space.
If I were you I would get a nice 8 or 10 in a sealed box and a set of amped component speakers... You could get some nice SQ that way.
