Need to change my setup
Username: Mmaudioconcepts
Post Number: 563
I never really got too many replies the last time i posted this. I really am not impressed with the output from 2 AQsdc2.5 12s.(4.28 cu feet tuned to 35hz) Its decently loud but not what I expected. SQ is pretty good. What are some single subs that would sound just as good or better but be an increase in output. around the 1000-1200wrms range. Im thinking a single 15.
Username: Bonhamd
Post Number: 1412
it is going to be difficult to make 1 15 louder than 2 12s on the same power
Username: Insearchofbass
Post Number: 10762
Move your tuning up to 40 hz with the audioque 12's.
Username: Deadrabit
Marionville, MO
Post Number: 1039
with the same power it wont get much better. tuning higher would help but the design of the box itsself will also make a difference. u can always have bj fish draw u soemthing out
Username: Deadrabit
Marionville, MO
Post Number: 1040
Username: Skibum12189
Cleveland
Post Number: 3003
you could buy my 15" tc3k and itd get near as loud as the aq's and sound 4x better
Username: Talon01
Team Revolution , Pa Usa
Post Number: 1728
dc audio lv4
fi bl
dd 3500
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5866
i'm selling my 04/05 RE XXX 15" if that would interest you at all..
Post Number: 564
I will tune my next box to around 38 to 40hz. also how much louder would two fully loaded BLs be on 3kw.
Username: Talon01
Post Number: 1729
on 3k i would do 1 15" btl fully loaded or 1 15" dc lv 4 with lv 5 coils. my dc 12's with that setup are loud as balls. i ran 7k for 30 sec avg at 145+ with a box tuned at 38hz
Post Number: 565
ok so i let my friend borrow the car and he comes back and out of nowhere my map is fried. He replaced it with this http://vanhorn1.com/fusionnvseries2500wattmonoamplifier.aspx
its a Fusion NV series. 1790rms@ 1ohm
with that power what should i upgrade subs to.
Username: Frkkevin
Post Number: 5874
perfect power for my XXX 15" :P
if indeed that amp does rated power.
Post Number: 566
the amp does rated power.
Username: Frkkevin
Post Number: 5875
buy the XXX :P
Post Number: 567
how are the Fi SSD's compared to the AQ SDC2.5s
Username: Surferdude9371
Get loud or go home....
Post Number: 1424
bump up to a fully loaded fi q from the ssd its the entry level
Post Number: 568
i have roughly 1800w to work with. Right now i have two sdc2.5 12 and im either going to keep them or get something better for the power i have.
Username: Nyyfan13
Yanks Fan USA
Post Number: 10619
I'm assuming you are looking at 2 SSD's for the 1800rms you have to work with correct? If so, that will be a real nice system. The SSDs are solid subs. I loved mine when I had it. I think you will be happy with 2 SSDs off 1800rms.
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2959
Yea I've had 2 12'' 2.5s and I've always wondered how they compared with SSD's. If anyone has had experience with both, please post.
Username: Nyyfan13
Yanks Fan USA
Post Number: 10620
Phil and I used to argue the SSD vs the SDC2.5s all the time. Of course we were both quite biased lol. I wanna say we came to a logical conclusion but I forgot what we decided :-(
Post Number: 2960
lol Yanks. Thanks for your help.
Username: Nyyfan13
Yanks Fan USA
Post Number: 10621
I do what I can Steve. Glad I could help everyone out so much
Post Number: 1425
i say do one fully loaded Q 15 or 18
