2 ohm stable amp
Username: Talon_es93
Trinidad, Co
Post Number: 813
what is the badest amp you can get for under 500 that is 2 ohm stable to push 2 15" mojos
Username: Nd4spd18
Philadelphia, PA
Post Number: 8638
ZX2500.1 used?
Username: Livin_loud
Post Number: 2671
^ yup...
closest thing to that i can think of is what i run actually. rockford fosgate x7. pushes around 1600w though...
Trinidad, Co
Post Number: 814
idk if 1600 is enough... thats what i been lookin @ but idk were to get a used zx2500.. thats what i was thinging to but its like 750 brand new... does earthquake still make that 2 ohm stable 3000 watt?? i member it was a small red one
Username: Snowball123
West Allis, WI
Post Number: 1421
Crossfire VR2000D? If you could find one used.
Trinidad, Co
Post Number: 815
i'll check... thanks man
Username: Stateprop486
PA
Post Number: 1668
http://www.caraudio.com/forum/showthread.php?t=357499
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2445
buy one of those kickers if you can. best bet for your money.
you could try a stetsom 2k6d theres a couple floating around but some people say they arnt too reliable for daily usage. theres also a hifonics XXV colossus on ca.com, i think the guy wanted 450 or something like that.
the colossus really isnt as good as the zx2500.1 but theres been some tests that show the hifonics will put out real close to 3k rms at 2ohms
