Cone area not always better?
Username: Deadrabit
Post Number: 899
u all know i have a wall and i am redoing it... after having it for a month.
so ill prolly have new subs this summer. but when i was looking at what i could do one of my old freinds (big into spl) told me that i would do better with only 2 15s other than 4. i didn't understand y.
i didn't get to talk to him long at all but he said something about the subs not getting full potental because the don't have the room.
what he does is makes his boxes usually around twice the cuft that is recomended for each sub.
so one 18 in 15cuft would be as good or better than 4 15s in the same area? that is what i am getting from what he said.
any one know anything about this? i know that its all try and try again but i don't want to buy more subs if i will get louder with less
i am not talking about power. like 1 18 4000 watts or 4 15s 4000watts
Username: Adelphia83
Colorado Springs, CO USA
Post Number: 117
Remedial English, my only advise.
Username: Surferdude9371
Get loud or go home....
Post Number: 1310
id do 2 18s
Username: Nd4spd18
Philadelphia, PA
Post Number: 8589
There is no way in hell one 18" is louder than 4 15"s. Assuming there they have the needed box space.
Username: Insearchofbass
Post Number: 10643
It sounds like your friend doesnt know what he is talking about.
Username: Deadrabit
Post Number: 901
i am thinking he is saying a box twice the size of what is recomended is best. doing that would be louder than a pair of subs with recomended cuft.
idk. i thought that some one on the site my be able to explain. maybe he is wrong
Post Number: 10644
It depends what your goal is but going to large on the box can hurt your spl.
Username: Deadrabit
Post Number: 904
i am talking spl only.
i have nothing to do put try it... with smaller stuff. this summer ill learn a lot. with that 18 BL i am going to try 4 cuft 8 cuft and something big like 15cuft
i guessing trying everything is the best. there is so many things people tell me and idk what to believe and what to laugh at
Username: Nd4spd18
Philadelphia, PA
Post Number: 8593
" a box twice the size of what is recomended is best. "
No.... wrong..... fail.
Username: The_image_dynamic
San Diego, California
Post Number: 4604
And this surpises you how exactly Sean?
Username: Th3pwn3r
I compensate...
Post Number: 8782
"There is no way in hell one 18" is louder than 4 15"s. Assuming there they have the needed box space."
Why does the 9918z kill every other setup out there? Hmmm, I'm pretty sure the guys right below him are using more than 4 15s and still can't come close. Someone needs to be schooled.
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14246
mistake most ppl make is trying to fit too many subs which sometimes ends up in each sub not getting a good amt of cuft to operate in ...2 subs in correct cuft\port installed correctly will kill 4 subs in not so idea conditions ......
Username: Deadrabit
Post Number: 907
what if i were to pench the box and make it smaller so at impedence it would get more wattage to the sub?
and rovin. how do u know how many cuft it really should have?
Username: Hittin1
Lake Charles, La. United States
Post Number: 1479
Username: Snowball123
West Allis, WI
Post Number: 1386
"how do u know how many cuft it really should have?"
by looking at the subs specs?
Username: Deadrabit
Post Number: 908
yes but like the BL it says 5 to 10 cuft. thats kinda a big range
Username: Tatonka
-[Team Audible Insanity]-
Post Number: 2351
There is no set cuft that every sub likes for SPL. There are just too many factors to say [sub here] needs [space here] to be the loudest it can be. It will depend on the vehicle and power.
How do you find the space that your subs need in your vehicle with your power to be loud?
LOTS OF TESTING!
Try to find some competitors that have your vehicle to see what box it likes. Also find some that run the subs you want to use and see what they have to say about thier performace SPL wise.
Very few get it right the first 2 or 3 times. SPL isn't cheap, and sure isn't quick.
Username: Deadrabit
Post Number: 909
so what i am going to do is make a really big box for this 18. like a 10 or 12 cuft box.
cut an inch out and burp it and find the best Hz. from that add a .5cuft box and attach to the inside of the box and do the math and make the port tuned to the same thing that was best.
keep putting .5cuft peices in and i should find the best cuft for it .
good idea?
Username: Ducka
Houghton and/or Macomb, MI United States
Post Number: 582
"Try to find some competitors that have your vehicle to see what box it likes."
Exactly why I go to nick with a lot of my questions.
Alero FTMFW!!
Username: Deadrabit
Post Number: 910
i don't know any one with a car like mine
Username: Hdubb
Team Revolution
Post Number: 3924
nick is right. if no one has a car like yours just start from scratch. and one important thing to have while you are testing is a pen and pad. write down every change you do, at what volume is does this. and so on and so forth.
Username: Deadrabit
Post Number: 916
i can't wait!
Username: Redliner
Wilmington, Ma
Post Number: 4528
ya they have those box specs for a reason. I wouldnt go out of that range at all cause if they didnt list it. They didnt do so for a reason. Probably cause it sucked lol
