Crx project
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5619
few things ive been piecing together
missing a few parts here and there.. ill get it running with the new intake manifold and hold off till i get some injectors/fuel pump/hondata
gotta get those SX 15s in there :-)
Username: Frkkevin
Post Number: 5620
Diamond Member
Post Number: 22518
sick man. that is going to be some serious power.
Username: Frkkevin
Post Number: 5621
the turbo has some slight shaft play so ill prolly get it rebuilt before the install.. prolly into something bigger :-)
its a turbonetics .63trim .. tial 38mm wastegate.. skunk2 intake manifold.. not sure what brand the exhaust mani is or the fmic.. still gotta mount that and do the piping.. new radiator too eeee
Username: Snowball123
West Allis, WI
Post Number: 1320
how do you have so much money?
Diamond Member
Post Number: 22520
he hordes turbos.
Username: Frkkevin
Post Number: 5622
i don't have that much money..
my wife is a stay at home mom so im the only one working.. between the mortgage on my house and other stuff i have to hustle some stuff on the side or find great deals
actually traded one RE SE 12" and $100 for the turbo stuff.. paid $60 for the skunk2 mani :-)
got the welder from work and the tools from a pawn shop hehe
the hondata s300 is still gonna cost me a good 5-600 though :-(
did buy some new tools though hehe!
Diamond Member
Post Number: 22523
when you gonna tune your legacy?
Username: Frkkevin
Post Number: 5623
Username: Frkkevin
Post Number: 5624
the legacy is tuned.. stage III on meth
paid for my TGV deletes but im waiting to save a bit and go with an EWG and retune... already have my larger intake and new turbo inlet since my old one was too small.. the maf was maxed out :-(
Diamond Member
Post Number: 22524
kev i came across this deal on the forum i go to alot. anyways i believe it was from a 4cyl accord. i don't know if it will work with my v6 accord though.
Garrett T25 w internal wastegate
log type manifold.
FMIC w Pipes.
e-Manage Ultimate.
RC Engineering 440 injectors.
HKS SSQV with the purple insert.
PLX devices with all the wiring, CPU's, and sensors.
Stage 2 CM clutch and flywheel combo.
I'll prolly let go of it all for $2500 obo. Remember guys this is only a feeler so make me an offer don't be shy.
Username: Frkkevin
Post Number: 5625
too small for a v6
besides that go with an external wastegate
Username: Th3pwn3r
I compensate...
Post Number: 8749
There's really no need for an external W.G. with such a small turbo. He'll be more than fine with a small turbo and an internal W.G. Have fun with that .63 trim =/
A pic is worth 1000 posts!!
Post Number: 18489
With that new house you'll need those tools eventually. Good stuff. Nice enough girl to support your interests as well.
Username: Frkkevin
Post Number: 5626
heck ive needed those tools living in an apt! lol
and rob there no way that turbo would be bueno on av6.. flow rate is not good enough and only 440cc injectors?!
Username: Th3pwn3r
I compensate...
Post Number: 8750
For his all stock and low boost application it'd be fine and have crazy spool, especially if he had two of them ^_^ Crazy spool.
Username: Th3pwn3r
I compensate...
Post Number: 8751
Oh and I'm assuming you're going to make your piping yourself right? That's going to be awesome when it all comes to life :-)
Diamond Member
Post Number: 22525
it won't be all stock rob. just watch. i'll surprise you next year. really surprise you.
i got the precat deletes coming in a few weeks.
Username: Th3pwn3r
I compensate...
Post Number: 8755
I won't be surprised no matter what you do to the thing. Well, unless you put a Supra engine in it, then I'd be surprised haha.
Diamond Member
Post Number: 22526
lol azz.
Diamond Member
Post Number: 22527
Post Number: 18490
Wow.
Username: Frkkevin
Post Number: 5627
chad just pick up a cheap sc300 and build it :-)
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 445
me wont
Username: Jtown
Texas
Post Number: 3251
nice
Username: Bernymac
Phnom PenhCambodia
Post Number: 4356
"chad just pick up a cheap sc300 and build it"
Thats what I wanted to do! sc300 with a 1jz or 2jz. I love that car. Anyways, what motor is that in the crx? b20? ls? The valve cover is smooth so I'm kind of confused lol. I would look it up but to lazy -_-.
Username: Frkkevin
Post Number: 5631
just an ls.. b18a1.. going to the cheap :-)
Username: Th3pwn3r
I compensate...
Post Number: 8760
With a safe and good tune you can probably squeeze 475HP before you blow stuff up haha.
Username: Frkkevin
Post Number: 5632
guy local made 615whp on 28psi out of a stock b18a1 for 2yrs before a valve retainer finally broke
hell 300whp in a gutted crx would be fast :-)
Username: Th3pwn3r
I compensate...
Post Number: 8763
Well, in B-Series the rod bolts usually take a crap before anything after that it's usually a sleeve that walks and bam. 300WHP in a gutted Rex would be fast, especially with a lean/small good driver.
Username: Bernymac
Phnom PenhCambodia
Post Number: 4359
Kevins crx ls-turbo vs robs crx gsr turbo? vs my ek k24? How about it guys.
Username: Livin_loud
Post Number: 2658
2jz ftw. that is all.
Username: Th3pwn3r
I compensate...
Post Number: 8765
"Kevins crx ls-turbo vs robs crx gsr turbo? vs my ek k24? How about it guys."
Ha, the K-series setup will be sick and expensive. When my setup is ready Kevin's won't stand a chance unless traction becomes too much of an issue on my end. I'm still sitting on money before getting my B18C fully built, I don't trust this economy to drop the $3500 into the setup right now. After that I'm looking at $1500 in headwork and 3-4k on a turbo setup and I'll probably run an LS trans for a bit unless I change out the gearing in my current trans.
Username: Frkkevin
Post Number: 5637
run the ls trans? thats the worst thing you could do :-)
im not trying to spend that much tho.. point of this crx is to build a cheap quick beater.. thats all an old honda is to me :-)
all i'd have to do to be on the same page as you is get a gsr head and ecu to match
if im dropping $5000 on modding a car i would not waste my time with the crx
like i told chad.. sc300 would be the cheaper old car to mod
Username: Th3pwn3r
I compensate...
Post Number: 8766
"all i'd have to do to be on the same page as you is get a gsr head and ecu to match "
What?! A stock B18B Vs. a fully built B18C hmmm...considering I'll be running a fully built race engine Vs. a stock running a GSR head and ECU would not get you on the same page. Besides, you do realize that the B16 VS a GSR head basically a pointless comparison since they're just about equal until you decide to port them but they perform very similar. You can look it up =/
