CD skipping when i play subs loud, help!
Username: Leapoldstotch
Post Number: 129
Is the bass making my CD skip or what? When i bump my subs way loud it will skip the CD every so often, but when i dont play it loud it never does it. Why is that?
A pic is worth 1000 posts!!
Post Number: 18065
Physics.
Try wrapping it with e-dead or switch to a mp3 player as an input source.
What HU are you using?
Username: Van_man
Boston South, MA
Post Number: 4260
try a squirt of wd40 in the cd opening.
Post Number: 130
So is that whats wrong, the bass is making it skip? Or am i losing power b/c of the amp and its shutting down for a second?
Post Number: 18066
A good hu will have an anti skip feature but with constant turbulance from the bass it will skip regardless. If you don't absorb this vibration it will only continue. Like the evolution from tape to cd we are just around the corner from a complete transformation from cd to mp3/usb formats. It's getting cheaper and cheaper with memory and does away with the skipping of the discs.
Post Number: 18067
LMMFAO Marc.
Username: Rovin
1 15 = 149.5 DBsTrinidad & T...
Post Number: 14140
some vehicles like mine the dash where the deck is mounted is not really solid so if i cross an estimated 145dbs my 860 premier skips ....maybe if u dont already have 1 is to buy a USB deck & use that usb ...
