Subs with different ohm coils
Username: Mendonmafia
Post Number: 1392
My friend is really stupid and for some reason bought one cvr with dual 4 ohm and the other with dual 2 ohm.
i told him he need to trade one of the subs for a different one.
he went to circuit city and they installed his system for him and they said it would be fine even though the subs have a different coil configuration.
so i went to listen to it and it dosnt sound bad. shouldn't it sound terrible with the subs each receiving different power and them being in a common chamber box.
Username: Brewsky
Prince george, British colu... Canada
Post Number: 69
well i dont think they would be receiving different power unless its going to a 2 channel amp it might give a strange impedance if mono like 3 ohm or something not to sure
A pic is worth 1000 posts!!
Post Number: 18013
"he went to circuit city and they installed his system for him and they said it would be fine even though the subs have a different coil configuration."
It shouldn't be hard to return one sub and properly match them. Should be an easy swap. He bought the subs there also correct? Amp?
Post Number: 1393
yea but what if they are wired in parallel. im not sure how they are wired up tho.
Post Number: 1394
he bought one of the subs there.
the amp is a visonik mono block. looks like a newer one not sure tho as i have never really kept up on my visonik products. i think its supposed to be like 500 or 1000 watts. its 60 amp fusing on the side i do remember that.
Username: Stateprop486
PA
Post Number: 1601
CC installation ftl and they will say anything to get away with it. ....
Post Number: 1395
yea i know thats exactly what i told my friend. he never listens to any of my suggestions.
Username: Nd4spd18
Northwest PA
Post Number: 8306
yeah hes an idiot alright.
