Uhh-ohh
Username: Hittin1
Lake Charles, La. United States
Post Number: 1153
I ran acroos a major problem... I seem to have busted something loose it the roof of my jeep. When the bass hits the roof of my Jeep sounds like something came loose due to the flex, ect..At first it sounded like I blew the side out of my box, but I got the noise to stop by putting pressure on the roof from the outside. Has anyone ran across this problem? What likely came loose? Crossmember weld maybe? How difficult is it to repair? Since I'll likely have to pull the headliner to repair, should I put some kind of sound deadener? If so, what should I use? Effective but inexpensive preferred. Thanks in advance.
Need help A.S.A.P. I have to weigh out my options with the hurricane, in case of mandatory evacuation...
Username: Hittin1
Post Number: 1156
C'mon guys... Need some advice..
Username: Th3pwn3r
I compensate...
Post Number: 8635
"Effective but inexpensive preferred."
JB Weld, super glue, duct tape, silicone or caulk.
/thread
Username: Hittin1
Post Number: 1157
sorry if I wasn't clear... That was refering to the sound deadener.
I need the repair to be done the best way possible. I don't know exactly what is broke up there but I doubt it will be expensive to fix... Was hoping someone else has had a similar problem and could let me know what the possabilities were..
Username: Hittin1
Post Number: 1158
How hard is it to remove the headliner in a 1999 JGC?
Username: Regguy
It does sound like a weld came loose on you. I had this happen in my PT Cruiser. The thing is rock solid and nothing rattled. Swapped out the in the door speakers for something with a little more thump and it loosened up something in the door. Everytime I played music with some deep prolonged bass, it rattled. Had to take it apart again and get someone to spot weld a piece back on. Tiny weld, but loud buzzy annoying noise.
Is the noise anywhere near the light in the roof? Perhaps you can reach it without taking out the headliner.
Best of luck with the storm!
Username: Drant19
DUB-C, TX
Post Number: 1153
i would take out the headliner to see what the problem actually is..
cheap and effective = peal n seal
^^ use a few layers to do the job
Username: Renegadesrun
Lafayette, IN US
Post Number: 998
peal and seal x 2
Found at Lowe's, Home Depot, Menards, etc etc
In the roofing section.
Username: Shade
Moxee, Wa U.S.
Post Number: 722
expanding foam between the 2 sheets of metal and then deaden it.
atleast that's what i would do.
