Giant Foam Surrounds
Username: Adelphia83
Colorado Springs, CO USA
Post Number: 80
It seems as though almost every subwoofer company is jumping on the "giant foam surround" bandwagon, offering at least a model or two.
IIRC, I first saw this on Audiobahn models, along with Power Acoustik and some other cheaper brands. Now I see them in almost every product lineup (Diamond Audio, RE, etc).
Common sense tells me that the larger the surround, the less cone surface area which isn't a good thing. Are there any advantages to these giant surrounds? I realize that a large surround can help with long xmax applications, but I've seen other surrounds that look to achieve the same thing without sacrificing cone area.
Case in point:
http://www.poweracoustik.com/pa2006/images/PRODUCT/ADUIO/SW/mofo3.jpg
Perhaps a better solution:
http://www.poweracoustik.com/pa2006/images/PRODUCT/ADUIO/SW/FX-10W.jpg
I'm using the PA images for reference only, not comparing or suggesting using these woofers in any way.
What do you think?
Username: Extrmndor3
Http://illuzonemu.serv..., ^^^Sick Game
Post Number: 8032
to be honest a good sorround can make a BIG diference in sound quality..
for spl you dont need too much xmax... and you dont need tall or wide sorrounds just a durable sorround thats it..
sorround are very important part of a woofer
Username: Safe_cracker
Chicago, IL US
Post Number: 4753
^Words only an 'Ultra Tard' could put together and understand, WAYYY TO GO BUDDY!
Smile sunshine, your SPECIAL... hahhahaha..
