Does it matter if the port is in middle left or right?
Username: Mike_16
Reedsburg, Wisconsin Us
Post Number: 1004
ok so on subwoofertools when u design one its always on the left side.so does that affect nythign when its in the center or the left?
Username: Basssquared
Kansas
Post Number: 2253
it depends on the automobile
Username: Mike_16
Post Number: 1005
96 pontiac sunfire. not that allot of people know but the rear seat folds down. but yea i have 35 1/2 wide 14 1/2 trunk opening and 34 deep . not that i woudl go that deep but yea. i just have a comp coming sunday and need to build box fast not sure if i should spend the time going ported. but i know its worth it. just not sure if i should go ported on the left or center
Username: Drant19
DUB-C, TX
Post Number: 1108
if your gonna do comps, go ported. that is if you have the room to build a correct ported box
Username: Mike_16
Post Number: 1008
yes i have the room pretty sure . the rec size for these subs is like 2 something a sub so i can fit about 7 cubes in this trunk..i think........anyways does it matter if the box is really deep ? say your box is only 14 high and 30 wide and 25 deep. does that matter ? dam subwoofertools isnt working.
