6x8 to 6.5
Username: Ba11in
Moneta, Va Us
Post Number: 8
just wondering what i would have to do to get 6.5 inch speakers to fit in a 6x8 hole?
Username: Chevelle
Lancaster, Pa Usa
Post Number: 74
I know kicker has a set with the templates.All you have to do is do a little cutting to make fit.
Username: Exige
CDT, Audiopulse Dealer
Post Number: 638
A Scosche SA68 adapter is what you need:
http://www.amazon.com/Scosche-SA68-Convertible-6x8-Inch-Speaker/dp/B0007TJDFM
Username: Adddisorder
Palm Beach, Florida
Post Number: 6338
or you can build them out of MDF, just make the MDF cover the stock hole and then cut out a hole for the 6.5 to fit.
