I need to know wat the best 12" sub is under 600
Username: Biggiesize92
Howey in the hills, Fl Usa
I was wondering wat the best 12" was for under 600 dollars im thinking about geting 3 of em i had my mind on l7s but not sure can sumone help me thanks?
Username: Loudnproud
Post Number: 40
L7's? no ther is lots better out there...I'm not much on whats good for what prices, but talk to some of the other ppl on here, they'll show you something better.
Post Number: 41
also is that 600 each? or 600 for all 3?
yea im just looking really for a amazing 12" forget the price wat is a good sub i also thought of powerbass 3xl
Post Number: 43
powerbass? not bad, but theres still definatley better....
another question, what type of system are you trying to put together
SPL....gets loud, but not very good as far as sound quality
SQ....Sound Quality is best, but doesnt get as loud as SPL
SQL...combination of both SPL and SQ
and to be honest, some of the best subs I've heard are the DD's....talk to Canaan about them.
Post Number: 8
600 each i really dont care about price i just need a nice hard hitting sub that aint shitty
Post Number: 9
like its gonna be a daily driver and yea i might take it to a local comp but i really want a SQL system and wat extaly does DD stand for and ok i will
Post Number: 45
Gonna stay on this post only now, instead of flipping between the 2
so...answer as to what kind of system you want
Post Number: 10
yea thats fine umm i did right up there lol
Post Number: 46
DD....Digital Designs...talk to Canaan
Post Number: 47
But though they sound great
DD's are really made more for spl
Username: Southernrebel
Monroe, Louisiana 3 DD3515s, 2...
Post Number: 6622
They are used alot for SPL, but when tuned for daily sound very nice.
Mini,
What is you full budget (amps, subs, batts, alt, wire, hu, etc)?
What systems have you heard that you liked?
What vehicle?
Post Number: 12
yea um its a s10 ext i want to inverse mount 2 and then one normal mount in between but i dont really have a budget just the more money it is longer it takes to get but i was just looking at the dds on you tube the 9512 and im not gonna lie there pretty badass and i dont mind a spl speaker casue ill be bassing the hell out of them
Post Number: 13
ive heared a blaezer with 2 power bass 2xl 10s and it souned good ive hearad a b3000 with 2 w7s and i really liked that
Username: Theweasel
2 12 FI SSD, Colorado U.S. of A
Post Number: 1227
the jl's are nice but expensive. look at some re sx's. should get plenty loud and the sound decent i believe
Post Number: 6623
If you want 3 12's that you can get for less than $600 each. Try the DD3500's...that is if you have the $ for a huge electrical upgrade and 4000wrms+.
If you don't want to spend a huge amount on power and electrical, try DD2512's.
Something like a DDM3 would work great on 3 or those...the M3 is pretty efficient.
W/ the M3, you could just upgrade your alt to ~200a, replace your stock batt, and add something like a Kinetik HC2400 right at the amp.
Just get a toolbox or hard tonneau cover and mount the amps/batts in the bed.
There are alot of subs out there that will get the job done for you. Look into RE, RD, Fi, DD, AA, DC, and etc. You can get amazing performance out of these brands for relatively low cost. (When compared to MSRP of mainstream brands)
Post Number: 6624
Also, when you mount 2 subs inverse and 1 normal.
Wire the 2 inverse subs out of phase w/ the normal sub.
When you get ready for a box...get ahold of me.
I'll help you out w/ a nice daily ground pounder.
