Texalarm won't shut off after replacing car battery
Username: Tex_alarm
The car battery was empty so I had to take out the car battery and recharged it. The next day I connected the battery and than my alarm went off.
It's a texalarm. I tried the off button on my remote handset, but it did not respond to it.
In the manual of the car alarm there was a reset way if you still have a special "codecard". I don't have it and the previous owner also don't have it.
I was thinking of disconnect the car alarm.
The alarm was connected by one blok with 22pins. is there a way to bypass the whole alarm so I can start the car again. Can I maby put current on a particular wire so the start engine will work again.
thx
