Box for fi q
Username: Nacnacrida
i might get the twelve so i do not have to make an angled box for a 15
i only have 14 inches in height to work with.
Is there any box plans someone has for a smaller ported box for the fi q 12 inch
Username: Tejcurrent
Post Number: 1420
Smaller than what? Do you have some max. dimensions?
i am pretty sure 2.5 is the smallest suggested..
I just cant go over 14 inches tall
Username: 420alldaylong
Post Number: 3734
Fi Q 12"
Ported box: 1.8-2.5 cuft @ 28-33Hz
any suggestions?
Post Number: 3758
I would say 2.5cuft at 32Hz
There are box spec on CarAudioforum under car audio help 101 then go to enclosure design and constrution help then free box spec.
CarAudio.com^^^^^
