Box help
Username: Surferdude9371
Im BTL Bumpin
Post Number: 1079
this is my new design for my FULLY LOADED 18 BTL question is what do you think the sqin for each port should be? thanks for the help box will be tuned at 33hz let me know if you need more info.
Diamond Member
Post Number: 21875
whats the cuft of the box?
Im BTL Bumpin
Post Number: 1080
i believe it is 7.65 after displacements
Im BTL Bumpin
Post Number: 1083
bump for sum help
Username: Insearchofbass
Post Number: 10017
How much power are you going to be running?
Im BTL Bumpin
Post Number: 1085
2500rms
Post Number: 10018
I would use four 4 inch aero ports to the right length with the displacement subtracted. But they cost alot. So id try making your own.
Heres a tutorial that will help explain it but apparently the links dont work. You could do a google search to find other examples
http://www.mobileelectronics.com.au/forums/index.php?showtopic=35639
Heres how to make a mold.
http://www.subwoofer-builder.com/flares-25mm.htm
Im BTL Bumpin
Post Number: 1086
thanks sean ill deff look into that have you made them b4?
Post Number: 10019
Your welcome. No I havent yet.
