Charging system upgrade?
Username: Will4992
NC
Post Number: 39
To use a jl audio 1000/1 in a car with a 110 amp alt would i need to upgrade my charging system?
big 3?
new alt?
certain kind of battery?
Username: Jakeyplaysbass
St. Louis, MO / ASU
Post Number: 3184
Could probably get away with just adding a new starter battery and a small battery in the back. A new alt is always a good thing tho, especially if you are going to ever upgrade or add a component amp.
Theres no point upgrading the big 3 on a stock alternator.
