Lanzar OPTI1535D
Username: Elandman
Is this sub really worth the money. They F@#$king expensive!!
But look like pure hotness.
http://www.lanzar.com/itempage.asp?MODEL=OPTI1535D
Anyone know about them or used them before
Username: Insearchofbass
Post Number: 9928
Lanzar was a decent product before they went out of business but later pyramid bought them out and took over. They are not good now. For that kind of money you can buy a solid product from other companies that will out perform that sub woofer and are built much better.
Username: Elandman
Damn. Then ill have to broaden my options. Any suggestions? Looking for 15inch that does some serious damage!!
Post Number: 9929
If your looking for a sub woofer thats a spl monster a digital designs subwoofer would be the one for you. A 3515 would be a level that would get loud with decent sq but you will need to give it around 1200 watts. What vehicle do you have.
