4 12 subs How big of box ?
Username: Beamerboy46350
LaPorte, IN United States
Post Number: 34
I got 4 12" Cuspid USA subs That I already know are crappy no need to tell me That I want to build a slot ported box for. I have no parameters on these subs like xmax, qts and such so any help would be great the space i have is 20X30X38 Thanks for any help. I wouldnt mind making 2 boxes wit 2 12's each so i could sell them to buy some good stuff
Username: Insearchofbass
Post Number: 9828
I cant believe im helping design a box for these subs but you have 11 cubic feet gross by your dimensions and I cant find specs for these subs anywhere but id say give them 2 cubic feet each net (after sub and port displacement) tuned to 36 hz with 50 square inches of port (25 square inches per box)....they probably werent designed to play real low but it should work
http://www.carstereo.com/help/Articles.cfm?id=31
Post Number: 35
The website on the boxes the subs came in says WWW.CUSPIDUSA.COM but it was no help at all.
Post Number: 9829
yeah I was there no help
Post Number: 9830
you could build the box and try them and if they dont sound right use the box you made for another brand of subs that work in that space
Username: Waresgaragestereo
Fort Valley, GA
Post Number: 226
did any instructions come with the subs? give em 2 cu ft each and devide the box.
Post Number: 37
Ok So using the link i come up with a box that is 38wx18hx15d thats a total of 3.62 cubic feet with a 3" slot port 24.5" long for 34hz sound right for these speakers or what ????
Post Number: 9844
what link can you give it so we can check it out
Post Number: 38
heres the link
http://www.reaudio.com/speaker_box/LPort_Box_Calc.html
and you can see the numbers to plug in to get the box is that right ?
Post Number: 9850
well I was saying 2 cubic feet per sub tuned to 36 hz with 50 square inches of port total for all four subs
Username: Denali_on_22s
I get Bucks like Milwa...
Post Number: 6061
get rid of those subs. please don't build a box for them.
Post Number: 6062
dude those are funky pups with a different dust caps.
Post Number: 42
heres the link
Does anyone have any opinions on the box and not the subs ??
Post Number: 9855
"well I was saying 2 cubic feet per sub tuned to 36 hz with 50 square inches of port total for all four subs"
I told you what I would do thats why I posted the above quote
Post Number: 43
Ive also managed to figure out with a dial caliper that the maximum excursion is 10mm eaach way if that helps at all ????
Post Number: 47
I just wanna know if that box would be ok just yay or nay would be fine ?????????
I bought the wood and am ready to build
