Stupid kids
Username: Qslimms
Swanton, Oh Usa
Post Number: 148
I had my sub sittin in my living room facing up in a box n my 8 yr old decides to use it as a spot to kneel and crushes in the dust cover
A pic is worth 1000 posts!!
Post Number: 17294
Pop it out with tape or something. If you're careful (very) a light duty vacuum can help take the creases out. As long as the adhesive held it's a cosmetic thing. I feel your pain. At home I can't take the grills off my speaks cause my little girl always thinks the caps are buttons lol.
Username: Drsmith
Montana USA
Post Number: 2645
drown him in the bathtub
it's the only way
Username: Qslimms
Swanton, Oh Usa
Post Number: 149
luckily its a diamond so the dust cap is aluminum so its popped back out but if you look at it from a angle you can see a few dents
Username: Gibsonguy
Storrs, CT USA
Post Number: 232
adoption
Username: Somedonniedude
Illinois United States
Post Number: 1790
So how did you get it back out? With tape? My old D6 had a dent in the cap (now my cousins), I might try and get it out now.
Username: Shortysetnies
Rock Vegas, NC US
Post Number: 2641
"adoption"
rofl
Username: Qslimms
Swanton, Oh Usa
Post Number: 151
is it the latest model d6 mine was pushed in n i just gave a little squeeze outside the dent n it popped back out
Post Number: 1796
What size is yours?
Username: Qslimms
Swanton, Oh Usa
Post Number: 153
its a 15
Username: Dsmith07
NC Http://com4....
Post Number: 849
i had a 12" D6 that had a dented dust cap whats up with all the diamonds and dented dust caps?
Username: Qslimms
Swanton, Oh Usa
Post Number: 154
i think its the material they use it gets dented real easy
Post Number: 1797
Mine was a 15" too. I don't think I have seen a used one with out a dented cap lol. But the sub in general can take a beating!
What kind of boxes have you used for yours and what do you think of them? My cousin and I are gonna build a new box for his truck. Were debating on sealed around 2.2 or ported 3.25cf @ 28hz. Right now its 3.25cf @ 32hz
Username: Safe_cracker
Chicago, IL US
Post Number: 4640
Just dent the other, matter of fact push them both all the way in won't hurt a thing! Intverted dust caps use to be popular. Polo..
Username: Qslimms
Swanton, Oh Usa
Post Number: 155
i only got one 15.donnie I got mine in a sealed 2.0 cu ft box it beats but i bet it would sound way better in a ported box.I was gonna have 1 built but the shop i got it from builds junk boxes and if i buy one online i go through subs so much it would just be a waste
Post Number: 17311
If inverted caps used to be popular then I had a slammin' set. All my dome tweeters were pushed in from my kids. To kids all they are to them are....
shiny buttons that scream "PUSH ME"!!
Username: Hdubb
Team Revolution
Post Number: 3810
if pushing in dust caps was cool then consider paul... miles davis. LOL
Username: Ridinspinnas
Windsor, Ontario Canada
Post Number: 275
lmfao hunterw, billy madison, i love his movies
