In search of a new system
Username: Gula187
Baton Rouge, Louisiana USA
Post Number: 132
i know everyone favors ported boxes but what will be the best choice four sealed 15's or four sealed 12's? im not competing just for daily pounding?
Username: Kingtutus
Lincoln, Nebraska U.s.a
Post Number: 357
four 15's
Username: Insearchofbass
Post Number: 9915
It depends if you have the room to properly run 15's. If you dont the 12's are the better option but not all sub woofers need as much airspace as the next either but you also need to decide on a sub woofer that suits your budget and musical tastes as well.
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2278
What's your budget? Do you already have an amp? if you dont how much power do you want to feed it??
Username: Gula187
Post Number: 133
well i have two zx2500's but im looking to get a 40.1..i have a $4000 budget for now but its most likely to go down to $3200
Username: Killswitchjd
Post Number: 771
you dont need quantity of subs to make more sound in all cases... ported boxes with the right sub sound great and get loud... so maybe 2 really nice 15's ported would work? Its up to you tho
Username: Loc_out
SOCAL2 RE 15 XXX
Post Number: 2282
what car is this all going into? i take it you already have the big 3 right?
Username: Gula187
Post Number: 134
a 89 caprice....and yea.
Username: Ctmike
Ct.
Post Number: 6329
"i take it you already have the big 3 right?"
question should have been take it you already have a ho alt.? but i'd assume he does.
