Kicker L5 Potential
Username: Basshead4life
Iowa
I got a 2008 kicker L5 12" dual 2 ohm in a ported box, i got it wired for 4 ohms and bridged on a rf 400.2 amp and with the walmart boomstick i got 137.9 on the dash with a 45 hz 0 db tone and got that same number with young jeezy's song put on. but could it have been more then 137.9 cuz i felt nausaus a few minutes after havin it play that loud. maybe 140's is my guess off 400 watts
A pic is worth 1000 posts!!
Post Number: 17171
140's off of 400w?
400w?
What was the last thing you ate?
Iowa
400 watts
a beef burrito
Post Number: 17172
BINGO. There's your nausea.
Iowa
i believe it was the bass too. ur just jealous and surprised an L5 can hit such high numbers on such low wattage.
Post Number: 17173
Yup. That must be it.
130's I'll buy. 140's................
Iowa
so maybe 140's off 600 watts u think, that is my goal.
Post Number: 17177
Remember the old ratio......for every 3 db gain there is a X2 power increase.
Iowa
Post Number: 7
yep
Username: Silvermopar
Nebraska
Post Number: 109
Lol just outa curiousity... What might a pair of Kicker 12" CompVR's hit when installed in a box 38"x13"x13" (those are inside demensions) with a 3x13 port in front constructed out of 3/4 Particle board. Im powering them with a ZX750.1 amp at 4ohms The so called Birth sheet read "889". I know it may be hard to tell due to so many variable but would any1 have a rough idea?
Username: Nd4spd18
Northwest PA
Post Number: 7808
LMAO...... walmart boomstick, there would be the problem..... those things are off by about 10 db
So yeah 128 db sounds about right
Theres only one accurate db meter out there and thats the TermLab
Username: Th3pwn3r
I compensate...
Post Number: 8283
"Remember the old ratio......for every 3 db gain there is a X2 power increase."
That's just theory and not directly true or accurate. L5s do have some potential though.
Post Number: 17182
So an L5 could hit in the 140's on 400w?
J/C
Remember I'm an old fug with old school mentalities.
Username: Southernrebel
Monroe, Louisiana 2 DD3515s, 2...
Post Number: 6466
In a mini-truck or a rex...yep.
Post Number: 17184
Then Luke needs to reveal the vehicle he is talking about.
Username: 04redmach1
Columbus, GA USA
Post Number: 2087
Also, is it the stock Keeker box or one tuned to 50hz in a smartcar :-)
Kevin
Iowa
Post Number: 11
my car is a 2001 ford taurus se
then 128 was loud enough and all i could stand till my ears started hurting a bit.
this is what i have for the bass...
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=510&i=2068VS12L5&tp=112
i'm satisfied with it
Username: Tdeaton1021
Near Tampa, Florida USA
Post Number: 4479
I listened to put on yesterday with 2 12 sdc2.5s, 1600w, and a PWK box it didn't make me feel sick. I guess in a sense it did. I was sick and bass was the cure. It sounded awesome, and I'm sure that was louder than your L5. But as long as your happy thats all the matters.
Username: Hittin1
Lake Charles, La. United States
Post Number: 482
2- L5's ported on pr100d did a 142.5 TL legal... 1 L5 in a trunk car w/ that amp...140+ not a chance...JMHO!
p.s. Boomstick = trash... i had one and used it on my solo X's... 124.4 in port..FTMFL!
Username: Hittin1
Post Number: 483
Silver mopar... mid 130's or so, my guess..
Luke... I hope you didn't pay 399.99 for that setup...
Iowa
Post Number: 12
well i went to check where my gain was and it was at 54 volts with the same 45 hz 0 db test tone, this was with the sub not hooked on the speaker outputs, so it was over 400 watts, i didn't know i was clippin the amp.
yes i did pay that much for that. was free shipping. i figured what the hell, i want somethin that slams. cuz i've never used a L5 before and was always curious about them.
plus ive been in car audio for 8 years and i'm almost 24. so i still got alot of other brands i wanna experience. but this hobby will never die for me.
Username: Hittin1
Post Number: 492
well... It's worth whatever you will pay for it..
Username: Hdubb
Team Revolution
Post Number: 3793
i got beat by a guy in a crx with 4 08 L5s and a hifonics brutus amp. did a 154
Username: Grayalien
boomstick= trash. take the battery out and look for a small adj. screw, turn to the right and two 6x9s will read 145db
Post Number: 17216
I just have to because of the name lol.
No offense.
Username: Lukesta
Iowa
i've seen that before so it's all good
Username: Lukesta
Iowa
ok kirk lol
