Username: Theweasel 2 12 FI SSD,
Colorado
U.S. of A
Post Number: 1151 Registered: Mar-06
Wednesday, June 11, 2008 - 07:29 GMT in that black aviator you recently installed, did it have a third row seat? and if so, how did you remove it?
Username: Jakeyplaysbass St. Louis,
MO / ASU
Post Number: 2829 Registered: Jul-05
Wednesday, June 11, 2008 - 17:00 GMT Yeah it had the third row seating. You take off the piece that covers the spare tire bolt and there are sets of screws and bolts under that. Its very easy you just need to find the bolts.
Colorado
U.S. of A
Post Number: 1152 Registered: Mar-06
Wednesday, June 11, 2008 - 20:30 GMT alright thanks a bunch i never use that thing, it's like a friggin surfboard
