Need an amp
Username: Gibsonguy
I need a class d mono block amp that will put out 1000watts to my subwoofer. the subwoofer is a d2. I have between $250-300 to spend. What are some good amps in that price range?
Username: Big_edge_head
Milwaukee, Wisconsin
Post Number: 2201
audioque 1200d.
www.audioque.com
Username: Gibsonguy
looks nice...i'll keep it in mind. any other suggestions?
Username: Kingandsons07
Lincoln, NE TEAM RD U.S.A
Post Number: 953
RD 1000.1 www.rdaudio.net
sundown SAE-1000D www.sundownaudio.com
so do you need it @ 1ohm?
Username: Frkkevin
Team DLSSuperNatural...
Post Number: 5138
Trevors nine.1 .. or mine :P .. his is cheaper tho
Username: Gibsonguy
yeah, my sub is d2 so i need it to put out 1000rms at 1 ohm or 4 ohms.
both those companies look good. i will email them to see what i can get for pricing.
Username: Frkkevin
Post Number: 5141
you won't beat trevors nine.1 for 180 shipped .. eD is under-rated.. does around 1400rms @ 14.4v
Username: Gibsonguy
im sure it's a great amp. i just prefer buying new.
Username: Hittin1
LakeCharles LA., La
Post Number: 357
1st choice: audioque AQ1200D
2nd " :memphis PR1000D
a couple that I used and like!
Username: Ctmike
Ct.
Post Number: 6143
if buying new go with the sundown sae1000d. great quality amp, and probably the best customer service around. also it's only $300 shipped from dealer.
www.kluvkustoms.com
^great place to buy from. i've bought from them before and they are super quick to ship and very nice to deal with.
Username: Hittin1
LakeCharles LA., La
Post Number: 358
what make/model is your sub?
Username: Gibsonguy
15" type r d2. i was told installed correctly, 1000rms wouldnt be overkill.
and i contacted all the usa internet dealers from sundown audio, and also contacted elemental designs about their amps. so ill just go with whoever gives me the best price probably.
Username: Ctmike
Ct.
Post Number: 6145
go with the sundown from kluvkustoms, cheapest you'll find authorized.
