HELP......
Username: Zena123
SHROPSHIRE
WE'VE GOT A PORSCHE 928 GTS WITH NO OUTSIDE DOOR LOCKS,WE HAVE THE CLIFFORD INTELLISTART SYSTEM REMOTE OPERATED,WE HAVE HAD A PROBLEM WITH THE CAR BATTERY DRAINING,MY HUSBAND THOUGHT IT WAS THE WIRES TO THE HORN AS HE HAD MESSED WITH THEM EARLIER,HE DISSCONECTED THE HORN SHUT THE CAR DOOR,WE CANT GET IN THE CAR NOW THE BLUE LED LIGHT INSIDE THE CAR IS PERM ON,THE INSTALLER OF THE ALARM SAID IT MUST BE IN VALET MODE,WE HAVE TRIED TO UNSET IT WITH THE REMOTE,IT ISNT THAT,WE CANT GET INSIDE THE CAR......HELP
Username: Zena123
SHROPSHIRE
DOUBLE HELP.....OK,SO WE'VE DONE A MAD THING,BROKEN THE DRIVERS SIDE WINDOW TO MANUALY DISARM THE VALET MODE....THE IGNITION STARTS THE BLUE LED GOES OFF,THE DOORS STILL WONT OPEN..TURN THE IGNITION OFF BLUE LIGHT COMES ON ,HAVE TRIED TO MANUALY TURN OFF VALET MODE BUT NO CHANGE .....PLEASE CAN ANY SHED SOME LIGHT..HHEELLPP...
Username: Zena123
SHROPSHIRE
HEY....WHERES THAT JEREMY GUY FROM AMERICA....MIND YOU IT WAS 3 YEARS AGO WHEN HE USED TO GIVE EXPERT ADVICE ON HERE.....HEY JEREMY I NEED YOU...ARE YOU THERE?
Username: Zena123
SHROPSHIRE
OK GUYS,ITS THE YEAR 2010...I AM 102 YEARS OLD...AND STILL TRYING TO GET THE DAM DOORS OPEN ON THE CAR ....WELL THE LATEST IS IVE MANAGED TO TURN VALET MODE OFF INSIDE THE CAR MANUALLY...BUT THE DOORS WONT OPEN ...THE IGNITION STARTS SO I CAN DRIVE THE CAR.WHEN I TURN THE IGNITION OFF THE DOOR LOCKS MAKE A NOISE THEN THE SIREN BEEPS ONCE...THE REMOTES MAKE NOTHING HAPPEN AT ALL,PLEASE ANYONE I LIVE IN THE MIDDLE OF NO-WHERE AND IT WILL COST A BOMB TO TAKE IT ANYWHERE,...COULD THE PROBLEM BE SOLVED BY CONNECTING MY LAPTOP TO THE BRAIN WITH THE CABLE,USING THE CLIFFNET WIZARD SOFTWARE? AND TRY THE TROUBLESHOOTING..OR SHALL I JUST BUY A BIKE..
