Silver Member Username: KrazyjUSA Post Number: 151 Registered: Jan-06 | its been a while since i have been on ecoustics. most of you probably don't remember my short career on the site but i do remember being one of the only girls. but besides the point. I need to put together a budget system. Subs,amps,coax speakers,wires,etc 97 altima. SQ setup. budget is $1000 |
Gold Member Username: RedlinerWilmington, Ma Post Number: 4368 Registered: Jun-05 | well welcome back id say try to find some w6v2's a cheap amp idk and some infinity kappa's |
Bronze Member Username: PeakohmPost Number: 63 Registered: Apr-08 | ^^agreed with that setup. nice setup/price |
Gold Member Username: CtmikeCt. Post Number: 6063 Registered: Feb-06 | you can start with buying my 15" aa atlas cheap![]() and welcome back. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16471 Registered: Jun-06 | I'll throw out there my 10" RL-i10 and Kicker ZX500.1 combo for $450 shipped. I can even throw in power wire, stinger in-line fuse holder and 60 amp fuses for less than I paid. Everything brand new. That would at least take care of the bass, which can be/is the most expensive side of car audio. ![]() Just throwing it out there. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3520 Registered: Nov-05 | components are way more expensive than subwoofers... the cisco kid |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16472 Registered: Jun-06 | Not necessarily the amps that drive them tho. You can spend too much on just about anything these days. ![]() |
Gold Member Username: JoebruceMach5Audio M... Post Number: 2057 Registered: May-04 | Ok here is a very nice budget system. I didnt include a HU since you didnt say you needed one. Total is about $920 plus shipping on the stuff so you'll be around $1000 with shipping. 5.25 Components(find some adaptor brackets to fit them) http://www.sonicelectronix.com/item_10495_DLS+Reference+RS5+-+RS5A.html Sub http://www.sonicelectronix.com/item_3646_Infinity+Kappa+Perfect+12d+VQ.html Amp http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=ra30 Wire http://www.knukonceptz.com/productDetail.cfm?prodID=KLM-K4 You will need a subwoofer box which you can build yourself or find a prefab sealed one for the sub. If you dont want to run components then here are some nice coaxials http://www.sonicelectronix.com/item_10498_DLS+Classic+425.html You can probly find everything cheaper on ebay. |
Gold Member Username: JoebruceMach5Audio M... Post Number: 2058 Registered: May-04 | If you dont want to get adaptor brackets to run 5.25 speakers then I would get these http://www.mobilesoundworks.com/ProductDetails.asp?ProductCode=457 Do you need a HU or do you have one? |
Silver Member Username: KrazyjUSA Post Number: 152 Registered: Jan-06 | i currently have: and eclipse 5425(old model)so i dont need a head unit. im going to take a look at your links. |
Silver Member Username: MmaudioconceptsPost Number: 485 Registered: Jan-07 | go with alpine type R 15" alpine type R 5x7 and 6x9 coax just need amps to push them |
Silver Member Username: KrazyjUSA Post Number: 153 Registered: Jan-06 | is the type R sub considered to be SQ |
Silver Member Username: Surferdude9371Im BTL Bumpin Post Number: 888 Registered: Mar-07 | if i were you id throw that whole grand into either mids or subs and save up for the rest better to get the best from the start |
Gold Member Username: CtmikeCt. Post Number: 6065 Registered: Feb-06 | type r is more sql. every sub mentioned here has better sq than the r. |
Gold Member Username: JoebruceMach5Audio M... Post Number: 2063 Registered: May-04 | "go with alpine type R 15" alpine type R 5x7 and 6x9 coax" No way, the links I posted are by far better than that. If you want a decent SQ system your front stage should be the biggest concern. The DLS components sound awesome. If you can use ebay then go with the DLS MS6A components,you can get them cheap there. |
Gold Member Username: Talon01Team Revolution , Pa Usa Post Number: 1238 Registered: Jun-07 | type r is a sql sub. the dls will be a great component set for you |
Gold Member Username: Denali_on_22sI get Bucks like Milwa... Post Number: 5723 Registered: Feb-06 | if you want a 10 go with pauls Rl-i. it will rock your world. |
Gold Member Username: TejcurrentPost Number: 1337 Registered: Apr-07 | I would focus on good equipment for the front, and sound deadener. Pauls setup will be good for bass, but again focus on the front. http://cgi.ebay.com/NEW-KICKER-ZX350-4-4-2-CHANNEL-AMPLIFIER-CAR-AUDIO-AMP_W0QQi temZ350055842126QQihZ022QQcategoryZ39739QQssPageNameZWDVWQQrdZ1QQcmdZViewItem 150 shipped That will power an active 2 way setup well, or even just drop-in replacements of the speakers you have. I would try to get a good set of 6.5 components. http://cgi.ebay.com/Focal-Polyglass-165-VR-6-5-2Way-Component-165-V2S-NEW_W0QQit emZ170216480527QQihZ007QQcategoryZ18800QQssPageNameZWDVWQQrdZ1QQcmdZViewItem would be a good replacement (I'd get a bracket made to fit these, they are 300 shipped I believe. So around 450 on your front stage. http://cgi.ebay.com/DLS-UR6S-6-5-2-WAY-COMPONENT-SPEAKERS-ULTIMATE-NEW-06_W0QQit emZ250243100572QQihZ015QQcategoryZ32819QQssPageNameZWDVWQQrdZ1QQcmdZViewItem Those would make it 500 on the front stage. You could buy pauls sub setup, to finish out the substage. That would leave you with about 100 for wiring, but if you really want sq then you should dump another few hundred in sound deadener. You could easily find cheaper speakers you would be happy with- you just have to listen to things and find what you like. Personally I didn't like my infinity Kappas- they were way too bright. Just my thoughts on them though. |
Gold Member Username: TejcurrentPost Number: 1338 Registered: Apr-07 | The type-rs sound pretty good, I prefered the type-x in a sealed enclosure if you have to go alpine. Not my first pick, and again personally I'd go with the rli deal with your budget and the real importance of a sub to your overall sq. |
Gold Member Username: RedlinerWilmington, Ma Post Number: 4376 Registered: Jun-05 | ya great price on paul's stuff and a great guy to deal with id jump all over that |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 2564 Registered: Mar-06 | Paul, I think you need to hold onto that until I go into the academy in July so I can get it. That sounds like EXACTLY what I want for my truck! |
