Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20637 Registered: Oct-05 | i want to buy one. should i just get the electric one or the one that uses compressor? i was thiking if i get the one that uses a compressor, i can get some other tools too. what's a good size compressor? |
Gold Member Username: BasssquaredKansas Post Number: 2102 Registered: Nov-06 | compressor FTW |
Silver Member Username: Hittin1LakeCharles LA., La Post Number: 248 Registered: May-07 | I like the electric one better.. It is easier to work with and is more versitle. But My air dremel is more for larger jobs. It all depends on the abuse you plan to put to it. I use both of mine A LOT! |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20638 Registered: Oct-05 | it would be used to cut through fiberglass and door panels. |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3504 Registered: Nov-05 | id buy the electric one since i think youll be using it in the car? the electric one is easier to use because its more maneuverable and fits in those tight places better |
Gold Member Username: JkidderWorlds gunna end, In 2012 Post Number: 3505 Registered: Nov-05 | the cisco kid |
Gold Member Username: Kpa2727Old Bridge, NJ USA ! Post Number: 1170 Registered: May-07 | electric is nice but chad deff get variable speed. i used 2 and one speeds and they are a b!tch to use and break cutting wheels alot. plus make sure its a authentic one no just a sears knock off. a electric 5 -10 speed whatever speed they come in i forget. real dremal is awsome, i use mine whenever i need cutting power on small projects. but variable speed is the only way to go. |
Silver Member Username: Hittin1LakeCharles LA., La Post Number: 250 Registered: May-07 | you should be good with thre elecric Dremel with your projects |
Gold Member Username: ShortysetniesRock Vegas, NC US Post Number: 2520 Registered: Mar-06 | dont get the battery powered one for sure. it wont keep a charge for more than 10 mins of constant cutting |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4447 Registered: Jan-06 | I don't think they make a single speed genuine Dremel. Honestly I cannot live without my Dremel and used it in every stage of car audio fabrication. Go with the XPR 400 http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10051& langId=-1&catalogId=10053&productId=100609465&N=10000003+10401010 Polo.. |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20640 Registered: Oct-05 | thats a nice one polo. can that thing cut through 3/4 mdf if needed? |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16388 Registered: Jun-06 | Air compressors are awesome but unless you have a 20 gallon unit it losses pressure fast with wheels of any sort. Electric for the win. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4981 Registered: Nov-05 | i have an electric one that has a fully adjustable speed.. probably is my favorite tool |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16392 Registered: Jun-06 | "it losses" Damn I suck. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4983 Registered: Nov-05 | oh.. i'd suggest the electric but make sure you get the flex shaft.. makes getting into places that are tight way easy i have a dremel brand with the extension.. love http://www.antonline.com/p_225-1-GP_332144.htm |
Gold Member Username: Safe_crackerChicago, IL US Post Number: 4448 Registered: Jan-06 | Hey Chad WTF would you cut 3/4" MDF with a Dremel for, isn't that where a saw would be used? LMFAO. A Dremel is good fabricating/finish work. Yes if you really needed to you could cut MDF but I would use a regular saw for that.. JMHO. Polo. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4986 Registered: Nov-05 | ive cut MDF with a dremel and wheel.. but of course what I was cutting was a very thin line |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20643 Registered: Oct-05 | its not like ima cut mdf with a dremel to build a box or anything. just want to know if its strong enough to cut it. also after i fabricate something and i need to make some adjustments, i might need to cut here and there where a saw won't be able to reach. |
Gold Member Username: Loc_outSanta Ana, Ca Resonant Eng... Post Number: 2042 Registered: Feb-05 | Chad i bought one when i cut my door panel. I'll let you use it if you want i won't need it until i get my speaker install in my back door. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4988 Registered: Nov-05 | just get yourself an adjustable electric wit ha flexible shaft and call it a day pawn shop ftw :P |
Diamond Member Username: BestmankindLos Angeles, CA USA Post Number: 20669 Registered: Oct-05 | not too many pawn shops around here kev. i think ima just get one at home depot or lowes. i really think a dremel is a tool that can be used in many applications. doesn't always have to be about car audio stuff. its would be a good investment buying one. |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 5003 Registered: Nov-05 | dude youll use it for some really odd things.. i use mine for all kinds of crazy things |
