Gold Member Username: Van_manBoston South, MA Post Number: 3878 Registered: Mar-06 | So, I cleaned the sub with alcohol, Super glued the rip back together. Used 4-5 coats of H2O, A water based contact cement, then a bead of silicone. Time will tell, and It gives me time to find a replacement surround. Thanks for the tips. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 5001 Registered: Nov-05 | actually looks pretty good ![]() |
Gold Member Username: Denali_on_22sI get Bucks like Milwa... Post Number: 5637 Registered: Feb-06 | yeah, damn fine job, man. that should work just fine. i would consider finding a way to make the silicone black or put a grill over it though. |
Gold Member Username: Van_manBoston South, MA Post Number: 3880 Registered: Mar-06 | acually, it will dry to a clear, But I plan on getting a JL grill for it. I throw all my tools in there and stuff so I dont want to puncture it. And I for got to put the trim ring back on. But Ill wait till I get the grill. Thanks. |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16426 Registered: Jun-06 | Nice work. Should keep you until you find one.![]() |
Gold Member Username: Van_manBoston South, MA Post Number: 3882 Registered: Mar-06 | Ya, Thanks. I think Im gonna buy like 6 new dub 13's. On sale for $21.00 each ![]() http://www1.epinions.com/t-jl-audio-w6 |
Platinum Member Username: WingmanaliveA pic is worth 1000 posts!! Post Number: 16428 Registered: Jun-06 | ![]() I'll buy 10. ![]() |
